Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old November 12th, 2017, 08:45 PM
Screwy Screwy is online now
Any way to exclude a device?
There are some devices I'd rather not have Alexa control, is there a way to prevent these from being discovered?
Old November 12th, 2017, 08:53 PM
rprade's Avatar
rprade rprade is online now
Disable voice command on the device's configuration tab:
The settings are explained here. Also note that this image is old, there is now an entry for Voice Command under the device name. This allows you to enter a different name to be used for voice control. If nothing is entered, it uses the device name. I will update that post this week.
I think it will remain in your Alexa configuration, but if you delete it it will not be rediscovered if that box is checked.
Randy Prade
Aurora, CO
Prades.net
Old November 12th, 2017, 09:29 PM
I'm afraid that doesn't prevent the echo from discovering or controlling devices. I disabled voice for all of my devices, yet the echo can still control and even discover new devices.
Old November 12th, 2017, 09:45 PM
Rupp's Avatar
Rupp Rupp is offline
You can also simply use the forget option if you do not want them included for voice commands
-Rupp
Old November 12th, 2017, 10:47 PM
rprade's Avatar
Hmm... That is not how mine worked when I tried the Echo last year and looking at my account, there are still only the two devices on which I have enabled voice control. I just tried to force discovery and it didn't discover any additional devices. I have both skills enabled.
I disabled voice on one of the two, removed the device from Alexa and it was not rediscovered. I enabled voice and it was successfully discovered.
I'm curious why yours is different.
Old November 12th, 2017, 10:50 PM
rprade's Avatar
For my system forget doesn't stop it from being rediscovered from a force discovery on the Alexa website. It may prevent auto discovery, though I have not checked that.
Old November 13th, 2017, 09:09 PM
rprade's Avatar
I used the forget on one of my two devices, yesterday evening. Last night at 10PM it was added through auto discovery. The behavior of the Voice Command checkbox on the devices is consistent. If it is checked, they are discovered and added, when it is not they aren't.
Old November 14th, 2017, 09:23 PM
integlikewhoa integlikewhoa is offline
It does for me. What devices are these?
Old November 18th, 2017, 07:31 PM
wkearney99's Avatar
wkearney99 wkearney99 is offline
Indeed, if they're discoverable by the Alexa device independent of being connected to Homeseer then changing their HS voice setting won't matter. But then you'd see them twice, once as native and then again as their HS device.
Old December 16th, 2017, 02:03 PM
So I did some playing around. First I updated homeseer since a was several versions behind. I've found that disabling voice prevents the echo from discovering a device, however... If the Echo discovers something, disabling voice in homeseer does not prevent the echo from continuing to control it.
These are my garage doors through the MyQ plugin. I have found that if you go in and set the controls to "not specified" the Echo will give you the "Hmmm, [device name] is not responding". So that's one way to prevent control of a discovered device.
You can of course also just delete them from the echo after disabling voice in homeseer.
Error trying to include or exclude - object is null mikee123 Z-NET 0 April 15th, 2017 04:52 PM
Exclude certain keywords from alert triggers madas WeatherXML 4 January 23rd, 2016 10:58 AM
How can I exclude X10 adresses rsisson Lighting & Primary Technology Discussion 11 August 26th, 2009 07:16 AM
Exclude from home mode Skibum ACRF Processor (3P) 1 October 20th, 2005 06:38 AM
Feature Request - exclude zones rirvine HAI/OnQ Panel (HS2) 4 January 24th, 2005 09:17 PM
