Sensor firmware 44, HS running 3.0.6.23 with serial PLM. After replacing the battery in my hidden door sensor, HS is not recording any heartbeat for it. The interval was set at the default (1 hour), so I changed it to 8 hours, which was successfully programmed. It has been a day and HS still says the last heartbeat was in October.
Mark, how should I debug this to determine if it is an issue with the sensor, the PLM, or the plug-in? BTW, the first link is for heartbeat reporting to the PLM.
Scott
Scott
