My Homeseer system is no longer talking to me through Sonos. Sometime in the last couple of days I installed the latest update from Sonos. I am not sure if it has worked since. It may be unrelated.
It certainly is possible that it is just something else on my system. Before I start digging into it I just wanted to see if anyone else has installed the latest Sonos PC Controller Software (which updated the Sonos system).
I can still control the music from Homeseer, it seems to only an issue when I use Sonos for announcements. I use use the line-in jack to feed the audio. I don't see anything obvious in the logs, though I have not done a thorough check. It could also be an issue with my audio hardware feeding Sonos.
Has anyone else installed the latest Sonos update? Is everything still working OK?
Lou
Lou
