HS3 BL Plugins and Linux
    What version of BLStat?
    That issue was in 2.0.37 but I believe I fixed it in 2.0.38
    Cheers,
    Bob
      Logs show this:
      May-15 7:51:22 AM Updater Error, package file not found: /usr/local/HomeSeer/Updates3/BLStat2.0.38.0/web.config
      The web.config file is in the updater directory for package though.
        This is the first time I have loaded the plugin so I do not know; just using the updater files that were installed which are BLStat 2.0.38.
          What files are in the [hs root]\bin\BLStat folder?
          Cheers,
          Bob
            Curious though relating to whether I should be seeing any errors in HS3 Logs with no hardware connected.
            I mean should the set up of the plugin be transparent to whether or not the hardware is present or is the plugin set up of the plugin dependent on the hardware present?
              #21
              None; missed that. You are going too fast for me....give me a minute and will copy them over.
              OK created directory BLStat and copied the three DLL files over.
              System.Data.SQLite.dll,.\bin\BLStat,0
              SQLite.Interop.dll,.\bin\BLStat,0
              netchartdir.dll,.\bin\BLStat,0
              Shut down plugin and restarted it.
              Still see this in the logs. There is a db file in the db directory.
              /usr/local/HomeSeer/Data/BLStat/BLStat.s3db
              May-15 8:49:28 AM Plug-In Finished initializing plug-in BLStat
              May-15 8:49:28 AM BLStat start BLStat plug-in has been initialized
              May-15 8:49:28 AM BLStat Info No Schedules have been configured in the plug-in.
              May-15 8:49:27 AM BLStat Error DatabaseFunctionsSingleton.GetDBConnection(): Caught exception opening database connection: SQLite.Interop.dll
              May-15 8:49:26 AM BLStat start Loaded configuration successfully
              May-15 8:49:26 AM BLStat start BLStat version is: 2.0.38.0
              May-15 8:49:26 AM BLStat start Initializing BLStat...
              May-15 8:49:26 AM Info Plugin BLStat has connected. IP:127.0.0.1:33940
              May-15 8:49:26 AM Plug-In Interface BLStat is running as a trial, 30 days remaining.
              May-15 8:49:19 AM Warning Cannot access remote plugin BLStat
                #22
                This must be something with linux because it is working for Windows
                Let me look into it
                Cheers,
                Bob
                  #23
                  Looking too here at the RW stuff rights of the new files.....I have to log in as root via SUDO now with Ubuntu 14.04 as they upped the security major; PITA.
                  OK checked RW stuff with root login. All OK. Shut down plugin and restarted it. Same error.
                  Isn't the SQLite DB same as the Homeseer DB stuff other than using the *.hsd name?
                  Well looking at the SPUD UPB plugin and there is no DB there. Guessing he is using the Homeseer HSD file.
                  Rob has only gotten the mysql DB stuff going for the HAI plugin. Robs is using the Homeseer HSD file I think.
                  Will also install these two plugins to the HS3 box running on Wintel...a little later as my time is now short this morning....
                  May-15 9:02:54 AM Plug-In Finished initializing plug-in BLStat
                  May-15 9:02:54 AM BLStat start BLStat plug-in has been initialized
                  May-15 9:02:54 AM BLStat Info No Schedules have been configured in the plug-in.
                  May-15 9:02:53 AM BLStat Error DatabaseFunctionsSingleton.GetDBConnection(): Caught exception opening database connection: SQLite.Interop.dll
                  May-15 9:02:53 AM BLStat start Loaded configuration successfully
                  May-15 9:02:53 AM BLStat start BLStat version is: 2.0.38.0
                  May-15 9:02:53 AM BLStat start Initializing BLStat...
                  May-15 9:02:53 AM Info Plugin BLStat has connected. IP:127.0.0.1:33947
                  May-15 9:02:52 AM Plug-In Interface BLStat is running as a trial, 30 days remaining.
                  May-15 9:02:47 AM Info Plugin BLStat with instance: has disconnected
                  May-15 9:02:47 AM Plug-In Shutting down Plug-In: BLStat
                    #24
                    BLOnkyo is now linux compatible
                    BLOnkyo is now in the updater and should work in Linux but will need testers.
                    Cheers,
                    Bob
                      #25
                      BLML2HS is now linux compatible
                      BLML2HS is now in the updater and should work in Linux but will need testers.
                      Cheers,
                      Bob
                        #26
                        I have converted a few more plugins for linux.
                        I have updated the list in the first post
                        Cheers,
                        Bob
                          #27
                          I now have a machine with linux loaded on it so that makes it easier to get plugins ready for linux.
                          Cheers,
                          Bob
                            #28
                            Blade "BL" Icon not found in Linux Updater
                            Bob
                            I just noticed a minor thing that for your plugins the BL icon is not resolving in the Linux updater - at least for me. The link points to:
                            http://dl.dropbox.com/u/7088674/Homeseer3/BladeLogo.gif
                            Is there a case mismatch that Windows is OK with but Linux doesn't like? Maybe bladelogo.gif or similar
                            Cheers
                            James
                            cheeryfool
                              #29
                              Looks like an issue with the updater for Linux
                              Cheers,
                              Bob
                                #30
                                Actually, my mistake. Apologies for rattling your cage. The machine I was using is restricted from accessing DropBox and I hadn't realised. I guess I can now easily see which updates are hosted on DB!
                                Sorry!
                                cheeryfool
