You may run into this issue and you may not.
The problem is that if you have BLGData installed, you may have a Newtonsoft.Json.dll file in your HS3 root folder.
In the newer BLGdata installs, it will install the file into the [HS3 root]\bin\BLGData folder but it left the Newtonsoft.Json.dll in the HS3 root folder
In the BLTVGuide install, the Newtonsoft.Json.dll file is located in the [HS3 root]\bin\BLTVGuide folder
** The Newtonsoft.Json.dll in the HS3 root folder needs to be deleted. **
I would try the following if you have this issue:
1. Shutdown HS3
2. Delete the Newtonsoft.Json.dll file from your HS3 folder (you can move somewhere else if you want to have a backup)
3. Restart HS3 and see if that helps
1. Shutdown HS3
