Need a consult.
I've had a simple stable z-wave lighting system controlled by my M1Gold security panel since 2005. I've periodically replaced or added switches as needed using a HA07 Homepro controller as the network primary controller without a problem.
The other day I bought a number of HS-WS-100+ wall switches to make all the older switches in the house consistent in paddle operation. several of the switches were Levnor, others were older HS switches (all 3-wire) . the new HS switch are an exact replacement.
However, I can't get any of the new HS switches to "add" to the network with my HA07. I've tried resetting the switch from the HA07 and using the manual factory reset process on the switch itself.... No joy. I also tried to exclude a current working switch in another location. But, HA07 didn't recognize the switch that I know is in its database. I'm thinking the HA07 has finally died!
Before I go through the process of factory resetting all the switches and using a new primary controller to reestablish the network I thought I'd ask if anyone had any other ideas?
Thanks for ant thoughts offered.
Dennis
Dennis
