HS-WD100+ dimmer circuit type?
    I can't believe this isn't mentioned anywhere; what type of dimmer circuit is used in the HS-WD100+? I guess if it isn't specified, it is likely a leading-edge dimmer like every other cheapo device on the planet. Which would be rather sad, as most of us are trying to use LED lights, which much prefer the trailing-edge dimmer circuit.
    Queue the "it works fine with my LEDs" responses . . . yeah, I know sometimes the old school dimmer still works. But they aren't really correct, create a lot of electrical noise, and often they don't work that well. Or work at all. That's where you get into murky waters.
    I believe this Post confirms your suspicion:
    https://forums.homeseer.com/showpost...1&postcount=16
    cheeryfool
      It does use the old forward phase control, too bad.
