You might try using startup delayer. I put HS3 in the 1st delayed position with a manual delay of 5 sec. I put deconz in position 2 and manually set the delay at 1min 10 sec.
With each re-boot it starts HS3 and then deconz and boots up all the way through.
Also go into win 10 startup (ctrl+shift+esc) and if any of them (HS3 or deconz) show up under the startup tab then disable them. Otherwise they interfere.
I am on 2.04.93 deconz and the latest jowihue and I can control all my lights and plugs.
Hope it helps.
Hope it helps.
