I have a couple of questions that I can't answer from the documentation on the HS-PA100+ appliance module.
(1) When I control the module manually using the button, it does not report it's status change to HomeSeer. Is this correct operation? Is there a way to change it with a parameter so that it does report? The documentation and specs say nothing about this.
(2) I've tried creating associations between two of the modules on Group 1. I receive a 'success' message that the association was created, but it isn't. When I retrieve the associations from the device, the new association is not shown. I'm trying to get a second module to turn on and off when the first module is turned on and off using an association like you would for wall switches.
Here's what the documentation says about associations. Maybe the answer is here, but I'm not understanding it:
I've tried testing with a few of my modules, and they all behave the same. So it does not appear as it's a defect. Any thoughts would be appreciated.
Current Date/Time: 12/18/2017 9:02:20 PM
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 8 Days 7 Hours 49 Minutes 14 Seconds
IP Address: 192.168.1.226
Number of Devices: 109
Number of Events: 30
Available Threads: 199
Enabled Plug-Ins
3.0.1.130: Z-Wave
Enabled Plug-Ins
3.0.1.130: Z-Wave
