Version 3.7 is now available.
Please read the release notes below and existing users please be aware of the bold items !!!
- Converted the plugin to a multi instance plugin.
Users of previous version, with more than one hub configured, should add an new instance for their second. third etc.. hub and scan and recreate the devices.
I know this might cause some inconvenience, but there is no other way to keep things clean.
- Added support for devices with the same name per plugin instance.
- Activity device will show status when connection problem with the hub occur
- Polling cycle can now be set in seconds instead of minutes. Existing users, will have to multiply their polling cycle setting by 60.
Setting the polling cycle lower than 60 seconds is experimental, it might cause performance issues on both the hub and HomeSeer itself.
- Code cleanup and minor bug fixing
