Can't locate Z-Net Backup file
    I am trying to backup my two Z-Net units for the first time using the PLUG-INS/Z-Wave/Controller Management/Back Up this interface action but I can't locate the backup file on my drive. HomeSeer confirms the completion of the backup with the below message but seems to cut off the location (...to the most available....). Can someone please explain to me how the location of the backup is determined or where to find it.
    Thank you.
    Getting controller data from interface Spidey-Z-Net-Remote to update the network information to the most current available...
    Saving network information to file: ZNet_C074B597.ZWave. Please wait...
    Done!
    Starting in the HS3 root folder, descend into Data folder, then into Z-Wave folder. File will be here.
    So in Windows,
    C:\Program Files\HomeSeer HS3\Data\Z-Wave
    or
    C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave
      Ok located the files under C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave. Not sure why my search by file name didn't fine the files. Also seems that if you are backing up more than one Z-Net you need to change the suggested file name else the existing file from your first Z-Net backup is over written.
        Thank you zwolfpack
