New user from Vera trying to figure out some of the basic, but different methods for operations on HS3.
I have a Cabana separated from my house by 40 feet and a pool house another 100 feet further back. I am thinking I will need 2 maybe 3 Z-Nets? To meet the WAF, I have scene controllers (ZRC-90US) stationed so she doesn't have to have a cell phone out to operate scenes / events. I also have a couple of GE remotes (45601) that can be directly associated with devices in the same network to turn on / off lights.
With Vera, I had 1 master Vera 3 (held PLEG and scenes) and 3 slaves versa (one just for locks, one at the cabana and one at the pool house and everything was connected via Ethernet).
1) Would each Z-Net be its own network and have its own set of devices? Or are devices added through any of the Z-Nets and just reside on HS3?
2) Does HS3 see these as separate networks? If they are separate, then the scene controller would only be able to "talk" with the devices on its own network.
3) MacroMark had mentioned something from another thread (sorry I don't remember where) about associating the scene controller with HS3 instead of the device and then use events. How is that done? It sounds like that would work fine for the ZRC-90US since it will run events, but the GE remotes will not use off commands and therefore will be direct light control and that seems like that would exclude it from being able to be associated with HS3 and still talk directly to the lights on separate networks.
Ideas?
Ideas?
