I ran a port scan and 25105 and 443 are the only active ports
Jun 19 Insteon HUB update 1016 will break the plugin
can anyone access the hub via a browser using
https://x.x.x.x without a port number; this would assume the default 443Mark
HS3 Pro 4.2.19.5
Originally posted by papapitufo View PostHow can we downgrade to the Hub's previous firmware version?
please post back what you findMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postcan anyone access the hub via a browser using
Originally posted by charlesmbell View Postsame errors as before with defaul https port
An error occurred during a connection to 192.168.1.11. Cannot communicate securely with peer: no common encryption algorithm(s). Error code: SSL_ERROR_NO_CYPHER_OVERLAP
Guys, if we can't get in via a standard browser, i can't get in via the plugin
i have an email into insteon for specifics on this changeMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostGuys, if we can't get in via a standard browser, i can't get in via the plugin
I can try restAPI or postman to see if I can parse whats changed, but not sure of the strings needed for access.
