I have dimmable z-wave switches and want them to be turned on at the last level when I say "OK, Google, turn on the ____ light." Is there a way to make this happen as opposed to having it come on at 100%?
On at last level
Originally posted by ksum View PostI have dimmable z-wave switches and want them to be turned on at the last level when I say "OK, Google, turn on the ____ light." Is there a way to make this happen as opposed to having it come on at 100%?
Be aware that there may be other implications of that however such as toggle buttons in HSTouch will instead toggle it between off and last level rather than off and on.
Another option is to use another go between device in that you have a virtual device that turns off/on and this has a voice command for Google, this in turn has events that turn the real light which has no voice command.
Resolved
So for Google Home the setup is the same. The Status Graphic setting for Control Use needs to be On as opposed to Alternate On with the Value kept at 255 while the original setting for On is changed to Alternate On.
Yes, this does change the way the Toggle works for HSTouch, but I personally like this better as it all now works the same as turning on the switch at the wall. Consistency is great, so all is good!
Thank you for getting me there.
KarlKarl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
HSTouch Clients: 3 Android, 1 iOS
Google Home: 3 Mini units, 1 Pair Audios, 2 Displays
