Zee S2 Web Interface Suggestions
    I am new to Home Seer and have been playing around with the HomeTroller Zee S2.
    Minor Annoyance:
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.398
    When viewing the Device Management screen - Configuration tab - the address dialog is not large enough to display all of the text.
    Can you make this dialog box larger so that it will show all of the text without cutting off the text?
    Wondering if you are using the desktop on the Zee2?
    Using the desktop GUI on the Zee2 will eat memory and increase utilization.
    Homeseer 3 is not a Linux desktop application and management of it is purely via the web interface.
    Chrome or Firefox running on the desktop will slow down the overall CPU utilization.
    It is much easier and faster to utilize a different on the same LAN local PC or laptop desktop to configure Homeseer 3.
    You can zoom out in the browser to see more and it'll be much faster.
    Auto mator
      I am using the Web Interface and have experienced the same issue with the latest versions of Edge, Firefox and Chrome.
        Auto mator
          Perhaps a screen shot to explain better your issue?
          Steve
            Here is a screen shot of the page you are writing about.
            Note here zoomed out so that I could see the entire page dialog.
            [ATTACH]65396[/ATTACH]
            Auto mator
              How do I paste a image into the reply?
                Webpage Capture Attached
                The attached images how the Address files that I is to short to see all of the text with out clicking into it.
                Is there a way to lengthen this field on the webpage so that all of the text is visible?
                  It could be a problem with your system fonts. I don't have that problem on any of my browsers
                  There is really no need to see all of the technology address as it is the Z-Wave controller HomeID (8 characters) followed by the node number (3 digits). There is really no reason to need to know the entire number, the node number is the only thing you may occasionally need. There are also other places to see it. It is on the advanced tab
                  and can be in a column in the Device Manager view
