Z-Health not triggering
    I've checked the option for Z-Health and specified it to run from 12:20am to 6:20am, but it doesn't start. What am I missing?
    The last time it worked, I had a problem where it would stall on one of my Schlage lockset. That was "fixed" in a subsequent update, but the Z-Wave Health option fails to run at all now.
    'Got it running.
      How?
        Originally posted by Moskus View Post
        How?
        At first, I thought it was because I had rescheduled it for an afternoon timeslot, but that wasn't what triggered it to start. It actually kicked in when I enabled DEBUG logging in the Z-wave plug-in. After disabling the logging, the Z-Health continued to work. I don't know if that makes any sense, but it repeatedly acted that way. Now, it works regardless whether the logging is enabled or not.
        When things start working for no logical reason, I don't question it; I just accept it.
          I may have spoken too quickly. It won't start this morning.
            If you set the trigger past 12 PM (to say 13:00), it will start. But before that it won't.
              My latest, working solution is to disable and re-enable the Z-Wave plugin. If I'm in the time slot for the Z-Health to be running, it starts right away.
                Yep . . . Z-Health won't start on its own, but restarting the Plug-In triggers it to run.
                  Kind of defeats it's purpose, don't it?
                    Mine wasn't running under .150. I have rolled back to .140 for other reasons. I am going to see if it runs under .140 tonight. I know it was running reliably a week or so ago, because I enabled it for two nights. I just don't know which beta I was running.
                      Re: Z-Health not triggering
                      Rather!
                      Sent from my SGH-I497 using Tapatalk
                        I've been trying it since .64, and never had it running...
                          My memory may be fuzzy, but I know sometime in the .108-.140 beta releases, I had log entries of it running two consecutive nights.
                            It didn't run under .140 either.
                              Interestingly enough, it started on its own at 10:26am this morning.
                              Interestingly enough, it is configured to start at 12:30am.
                              No one was home to trigger the startup. Really weird.
                              Jun-10 10:26:11 AM Z-Wave ZHealth is starting Z-Wave network optimization for 1001631D (Z-Stick).
