Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Insteon Plug-in
HomeSeer Insteon Plug-in Discussions related to HomeSeer's own Insteon Plug-in
Old December 27th, 2014, 06:21 PM
kideon kideon is offline
Power outage
Just sat through a power outage though homeseer remained operational on backup power. When power was restored the I stein plugin is showing no interface found though it is now receiving power. Is this a bug or an issue with the plm?
Old December 27th, 2014, 06:30 PM
Restarting the plugin fixed the problem. Is there a workaround?
Old December 27th, 2014, 09:07 PM
mnsandler's Avatar
Insteon Overlord
kideon,
the plugin doesn't understand what a power outage is so you must manage the process.
In general when the plugin can't communicate with the plm, an Insteon trigger will be fired: initially, Insteon "Interface stops responding", and then finally "interface crashes".
In order to start the plugin again, there is an action insteon "enable interface" that should restart comm with the plugin if everything else is good (ie power, etc)
so in general, when power is restored you can do fire the above action, or just restart hs completely depending on your needs.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old December 29th, 2014, 10:08 AM
mnsandler's Avatar
Insteon Overlord
Originally Posted by mnsandler View Post
kideon,
my comments are only related to my plugin. didn't realize i was responding to a post in this forum.
HTML code is On
Power Outage detection FlyBoyBob HomeTroller-SE 16 January 21st, 2015 01:16 PM
2413U Power Outage Issue kdlklm Insteon Plug-in (Mark Sandler) 6 December 19th, 2013 03:08 PM
power outage - best practices? completelyhis HomeSeer General Discussion Area 26 April 25th, 2008 03:00 PM
Power up sequence after power outage question RAM HomeSeer General Discussion Area 6 September 15th, 2006 07:47 PM
Can I fix a power outage? beach HomeSeer General Discussion Area 9 March 12th, 2004 05:11 PM
