Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Insteon Plug-in
HomeSeer Insteon Plug-in Discussions related to HomeSeer's own Insteon Plug-in
Old June 5th, 2015, 03:42 PM
rkshack rkshack is offline
2413u problems - Solved!
I have a basic insteon set up going and wanted to change over to homeseer. I have the Hometroller zee. I got it this past Christmas. I purchased a 2413u as a controller and plugged it in. Now when I go in to hsinsteon plug in configuration I get: Error: Cannot find controller. I am not sure how to proceed. I have set the com to usb1 and usb2 and neither worked.
Rkshack
Here is what the log says:
Jun-05 7:49:30 PM Plug-In Finished initializing plug-in HSInsteon
Jun-05 7:49:30 PM HSInsteon ERROR Cannot connect to port: /dev/ttyUSB0
I think by turning off x-10 plug in and then turning on insteon I got it up and running. I can control devices. If I turn x-10 on with cm11a compatability it breaks the insteon and it will stop working. I can get insteon working again by turning off x-10 and restarting insteon. If I try to start x-10 with the ti103/203 mode then it will not get past starting.
Any one can help me?
Rkshack
Old June 7th, 2015, 02:18 PM
partially solved
I removed the zstick and now hinsteon can find the 2413u device and it works well. If I reinstall the zstick everything breaks. Any suggestions.
Old June 7th, 2015, 03:56 PM
solved
Ok so what I did is removed the 2413u from the zee. Got the zwave set up and rebooted.
I then inserted the 2413u usb cable. I made sure I picked the opposite port address and then started the plugin. This time everything worked well.
rkshack
HTML code is On
X10 problems ? related to Powerlinc 2413U Jimbo109 Lighting & Primary Technology Discussion 2 October 25th, 2012 07:02 PM
Problems with Insteon Powerlinc 2413U Jimbo109 Insteon Plug-in (Mark Sandler) 18 October 18th, 2012 07:12 PM
2413U issue - Solved! Ken LaCapria Insteon Plug-in (Mark Sandler) 1 April 24th, 2012 12:26 AM
Getting HomeSeer (latest Version) to work with Insteon 2413U USB - Solved! mrmohouse Insteon Plug-in (Mark Sandler) 10 December 15th, 2011 03:07 PM
HomeTroller SE-PRO Driver Problems - Insteon 2413U Jeff_M HomeTroller-SE 4 September 19th, 2011 12:41 AM
