Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Insteon Plug-in
HomeSeer Insteon Plug-in Discussions related to HomeSeer's own Insteon Plug-in
Old February 19th, 2017, 09:28 PM
ilkgmmn00 ilkgmmn00 is offline
Insteon mini remote (8 button)
I have a USB dongle for the insteon connection, and I am trying to set up an 8 button mini remote. It does add to the insteon plugin successfully, but only as a 4 button remote. I have looked through the insteon help files and tried to set it as an 8 button toggle, but for some reason even deleting and re-adding to HS does not fix this.
Does anyone have experience with this combination, or maybe some tips to fix this? It seems that buttons A-D are registered as 1-4, but the E-H buttons do not do anything.
Thanks in advance!
Old February 19th, 2017, 10:25 PM
mnsandler's Avatar
Insteon Overlord
what plugin version are you running?
you might try a factor reset on the remote.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old February 20th, 2017, 02:12 AM
I just realized I posted this in the wrong forum. I am using the HS insteon plugin. My apologies!
I will attempt resetting the remote, however, and see if that helps.
Can this thread be moved to the HS insteon forum?
Old February 24th, 2017, 09:20 AM
I have found that the 8-button remote is not supported by this plugin. After trying the paid Insteon plugin, it works as expected.
Old February 24th, 2017, 11:10 AM
mnsandler's Avatar
Insteon Overlord
I will update the plugin comparison chart on the following thread
https://forums.homeseer.com/showthread.php?t=184037
thanks for posting your findings.
HTML code is On
Question about Insteon Mini Remote battery replacement mrceolla Lighting & Primary Technology Discussion 1 December 18th, 2015 02:15 PM
Mini Remote 8 button in Scene mode weird behavior sbueffel Insteon Plug-in (Mark Sandler) 4 November 4th, 2015 12:02 PM
Adding new Insteon 2342-242 Mini Remote devoir Insteon Plug-in (Mark Sandler) 1 January 4th, 2015 06:22 PM
Mini Remote shanbaum Insteon Plug-in (Mark Sandler) 5 April 21st, 2014 11:55 AM
Programming an Insteon 8 button mini remote. bdee1 Lighting & Primary Technology Discussion 0 September 23rd, 2013 09:28 AM
