Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Zigbee Plug-in
HomeSeer Zigbee Plug-in Discussions relating to the Zigbee plug-in
Old September 30th, 2017, 04:51 PM
Richel Richel is offline
ZigBee Error:There was an exception retrieving the authorization token
I am trying to get the Homeseer Zigbee plugin to work with my Zigbee OSRAM Lightify gateway. The gateway is working just fine and the android app indicates that the app is working via both local and cloud control. However, the Homeseer plugin cannot connect to the cloud and I am getting the following in the log: ZigBee Error: There was an exception retrieving the authorization token. What do I do next?
Elliott
EDIT: This was fixed.
Logitech web service response does not contain a login authorization token Duc998 Harmony Hub 26 February 16th, 2018 11:38 AM
Login has no authorization token nsomniac Harmony Hub 4 July 27th, 2017 05:35 PM
Login Authorization Token mistermike Harmony Hub 4 June 8th, 2017 03:47 AM
Logitech web service response does not contain a login authorization token timmarks Harmony Hub 19 March 6th, 2017 10:41 AM
3.6.5.0 - Logitech web service response does not contain a login authorization token bholio Harmony Hub 7 February 8th, 2017 07:43 AM
