Zseer+ - All nodes fail response test
    I installed Zseer+ and tested my network. All nodes fail with the response test. The command test pass with no failed commands but not a single response goes through, I get an error:
    Testing node 8...
    Issue getting node level : Timeout OK
    I get this error for every node but only for response tests. I use an HS3 ZEE S2 Edition 3.0.0.318 with version 3.0.1.130 of the zwave plugin.
    Any suggestions on how to fix this?
    Same problem.
    I just bought Zseer+ hoping it might help me with some zwave issues. I ran it and it is telling me that over half my currently installed devices cannot be found. Same issues as rbeauch above.
    Testing node X...
    When I first fired it up, it says:
    Could not contact node X without routing
    Could not contact node X at all
    I had two dimmers unplugged so I get that they could not be contacted, but 35 others? If the network cannot contact them, how do events get completed.
    When I click on documentation, nothing happens so I am unsure what this really means. I run reports and nothing happens. What can you actually do with Zseer+??
    I am a newbie to zwave, so if this is a dumb question, please feel free to let me know! :-)
    Rob
