For my "Last Zone Faulted" device I have a zone on partition 2 showing up as the last fault. When I click on the device I see the proper zone fault but the status still displays the wrong zone. I tried to uncheck partions I don't use but the plugin reverts back to them whenever I go back to the "Last Zone Faulted" device.
11/8/2007 05:38:34 AM jvCaddx Plug-In Error An unexpected error occured in the showTrackingHistory function/subroutine: [System.NullReferenceException: Object reference not set to an instance of an object. at dbModule.getTrackingData(Int16 pRecCount, Int16 pZone, Boolean asc) at HSPI_JVCADDX.HSPI.showTrackingHistory(StringBuilder& pHtml, Int16 pZone)]
11/8/2007 05:38:35 AM Info Web Server authorized local login successful from: 127.0.0.1 User: David
11/8/2007 05:38:39 AM Info Web Server authorized local login successful from: 192.168.1.100 User: David
11/8/2007 05:38:39 AM jvCaddx Plug-In Got item PartitionCheckBox with a value of Part
11/8/2007 05:38:39 AM jvCaddx Plug-In Got item TrackingDisplayCount_field with a value of 11
11/8/2007 05:38:39 AM jvCaddx Plug-In Got item ref_page with a value of deva7221
11/8/2007 05:38:47 AM jvCaddx Plug-In Got item PartitionCheckBox with a value of Part
11/8/2007 05:38:47 AM jvCaddx Plug-In Got item HideDebugButton with a value of Hide Debug Info
11/8/2007 05:38:47 AM jvCaddx Plug-In Got item TrackingDisplayCount_field with a value of 11
11/8/2007 05:38:47 AM jvCaddx Plug-In Got item ref_page with a value of deva7221
11/8/2007 05:38:59 AM Database Item Saving Device Last Zone Faulted
11/8/2007 05:38:59 AM jvCaddx Plug-In Last Zone Faulted changes for plug-in jvCaddx Plug-In will be saved!
