Can you add images to that default path?
Remotec ZRC-90us on Homeseer
I had also problems with including the device.
First I follow the manual of the ZRC-90 (Z-wave learning mode)
I put the zwave stick in the inclusion mode and pressed L on the device. After this the device was ready but the button presses didn't result in a reaction of the scenecontroller in the devicemanagementpage in Homeseer.
After some trial and error I found the solution.
Just press L on the device first and after this the inclusionbutton in de zwave interface in Homeseer. The device is now ready in the devicemanagementpage and react on the presses of the buttons.
I have a problem in that if you use button one short press and then you need to use it again it will not work. There is no change seen in the device.
Is there any way to use the event triggered to do the actions and then remove the button 001 text in he device. Set it back to nothing so that it is ready to see button one change again.
If you use button one quick press to trigger an event but then need to do the same action again it does not work. The trigger is a change in the device to say button 001 pressed but once activated it remains the same until a different but on is pressed. Is it possible to add an action to 'reset' the device to no button pressed so that it is ready to see the device change again?
I have some of these and they all work great using the easy trigger plugin. They have 4 selections per button press as you know and with the plugin there is a toggle selection that let's you use each button press selection repetitively. So essentially you could control up to 32 devices.Last edited by cowinger; April 4, 2017, 10:39 AM.
Originally posted by Frogstar Warrior View PostThe event I am using is triggered by Device changes state and becomes ***.
The problem is that button 001 single press used twice in a row (minutes apart) is not seen as a change in state.
