Originally posted by scorp508
View Post
Propane Monitoring
HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Z-Wave:,RaspberryIO:,AirplaySpeak:,Ecobee:,
weatherXML:,JowiHue:,APCUPSD:,PHLocation:,Chromecast:,EasyTr igger:
Originally posted by scorp508 View PostI'm actually about 45 miles south in Lakeville and just put Boston there so people quickly have a general idea where.HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Originally posted by macrho View PostLooks like the TankUtility only takes reading once a day
I added a few more fields to the script
I have a generator and when that thing kicks on, the usage can go way up.
Looks good; glad someone else is making use of it. Are you getting that propane price remotely or is that something you are manually entering?
The cheapest propane I found around here is $1.99 a gallon. My company is boning me at $2.70.HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
They are talking about -30 this weekend, hopefully that doesn't happen
Last time the power went out at around -20 and the generator didn't kick on
I manually entered the propane price
I modified your code to retrieve the device id so I shouldn't have to touch the code again (or until their API changes)
I wonder how much work it is to create a plugin. I'm not a vb.net guy but can work my way through it, more or less
I don't think their API will change much. It is published, so usually if they were to modify it, they would add to it. I think I read there was talk about reporting battery status. That can be kind of tricky.HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
The ability to temporarily increase the reporting frequency would be a nice touch. Something that basically says "Decrease time between reports to X hours for the next Y reports." As someone mentioned if you're running on generator you may want a bit more vision into how you're doing if it is an extended power outage. Or just look at the gauge I suppose... but what fun is that?
I think there is a spot on it which will cause it to issue a reading if a magnet passes over it. Might be possible to have a little electro magnet fire from HS. Maybe a 9 volt battery might be needed...HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
You can retrieve a list of devices associated with your account. Here's the documentation: http://apidocs.tankutility.com/#devices
Or you could set up 3 separate scripts with unique names for each measure
I only have one tank so my script doesn't iterate over the devices
