Known issue:
IKEA Tradfri and HomeSeer -> TrådfriSeer!
Originally posted by mrhappy View PostMany thanks, I was reading twitter earlier before I was aware of the update and there is some considerable anger directed towards Ikea for this little change!
Anywhooo, it's fixed now (or so I hope). See version 0.0.1.5 in the first post!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by mrhappy View PostThanks for the fix, all working OK here
I have to admit I was a little nervous. I've only tested the solution for 10 minutes after it was fully implemented, and only on one system!
However, it wasn't that much of a change, so I figured if it worked once, I had found the solution.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
I have been having a few 'drop outs' which resolved if I de-initialised and then re-initialised the plugin.
I saw the updated version and installed it. Now I get;
Initializing plug-in(2): TradfriSeer Instance::Value cannot be null. Parameter name: sSTACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
I just handled that such a message. It turns out the key (from the back of the unit) was wrong.
Apparently, the new version isn't as forgiving as the previous firmware.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostI just handled that such a message. It turns out the key (from the back of the unit) was wrong.
I have discovered that my hub appears not to be updating, it is 1.0.0008. The Android app tells me that 1.2.42 is the latest version. However the same app tells me I'm up to date. I emailed Ikea but got an unhelpful response. Is there a way to force a hub update?
Originally posted by IanIreland View PostI'm not sure that is my issue, I have the key as a text file and so copy and paste when needed.
I'm not sure if you can force an update, but 1.0.0008 is VERY old!HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Nope. Runs even on Zee2.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
On Linux? It's "/usr/local/HomeSeer"HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
This is a side topic as such - but maybe relevant for some.
In my earlier posts I was having issues.
I'm now on my third Tradfri hub and now have a better understanding of the issue.
I have a Draytek router. They are a good router with lots of defense built in, so I am loath to stop using.
Tradfri hubs do not play nicely with the DHCP on my router. I turned off the DHCP, set up another DHCP server and I could connect and configure Tradfri. Back to the Draytek and nothing.
If I find a solution I'll post it.
