Way2Call works fine with Windows Homeseer 3.
HS3 and way2call Plugin?
Did a quickie how to over here.
How to use Windows Homeseer 3, HSPhone and Way2Call
Basically it is installing the drivers, plugging in the W2C box and testing with the W2C Wizard. Once this is done with HS3 in off mode. Start up HS3 and you will see the W2C device in the drop down on the Homeseer Phone tab in HS3.- Pete
ITguyHS,
I did the listening test and connected a phone to the way2call unit. When I executed the script with the phone on hook the second and third leds blinked on and off quickly but apparently did not dial because external piece of equipment didn't respond. When I manually took phone handset out of cradle I got the dial tone and I heard the touchtones and the external piece of equipment responded correctly. As soon as I lifted the hand set from crade the third and fourth leds came on solid and tones were dialed. With the handset in the cradle it doesn't seem like the script commands are actually taking the phone off hook properly. Now I noticed in my hsphone settings for modem it shows way2call as the selected modem on default line. I can't execute the script remotely when I have to manually phsically take the connected handset off hook. Just wondering if we are using correct commands to take phone off hook and to hang up the phone? It is working but certainly not in a manner that is useful when I physically have to take handset off hook to get it to work. Your further thoughts are much appreciated. Also in an earlier post Pete had mentioned something like this:
Phone Off Hook:
&HSP.HIPcmd 1,&H14,&H0
Send Touchtones CID/Numbers:
&HSP.HIPSendLocalCID 1,"test","12345"
Go Onhook:
&HSP.HIPcmd 1,&H04,&H0
Would the above statements work and how would this be assembled into a script to be executed from a manually triggered event and what extention would we use to save file as? Would rather use your method if we can get it to work without me being there to take handset off the phone cradle. I would think this should be something that can be done? Again your thoughts and ideas are much appreciated !!!!!! Thanks Much !!!!! I will also set my internal phone system up like yours. Will be easy to do as you explained earlier...Rick
Originally posted by Rick Bonari View PostI did the listening test and connected a phone to the way2call unit. When I executed the script with the phone on hook the second and third leds blinked on and off quickly but apparently did not dial because external piece of equipment didn't respond. When I manually took phone handset out of cradle I got the dial tone and I heard the touchtones and the external piece of equipment responded correctly. As soon as I lifted the hand set from crade the third and fourth leds came on solid and tones were dialed. With the handset in the cradle it doesn't seem like the script commands are actually taking the phone off hook properly.
Since the external equipment responded in the "off the cradle" situation, at least we can eliminate the tone spacing and duration as a concern.Fred
HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
Rick,
Here's something new for you to try. As usual, rename it to a .vb. You won't be able to do the "listening test" with this one. I think that's because of the way we're controlling the "off hook", but not sure. Anyway, when I run this one, the "off hook" light on the W2C comes on, then goes off after the tones are sent, so it's doing something different. Let me know how it goes.Attached FilesFred
That is really great all of your help. I was wondering if my sytem (way2call) is acting like yours so far?
Thought maybe there was someting wrong with my way2call unit. However if it is wrking exactly like yours then that shouldn't be the case?
Also I noticed when I shut down homeseer and bring it back up all my homeseer phone settings are gone. This is inspite of the fact that I save them before shutting homeseer down. Clicked on save in bottom left corner.
I will give that new script a try ASAP. Again thanks much !!!!!! Rick
Originally posted by Rick Bonari View PostI was wondering if my sytem (way2call) is acting like yours so far? Thought maybe there was someting wrong with my way2call unit. However if it is wrking exactly like yours then that shouldn't be the case?
Also I noticed when I shut down homeseer and bring it back up all my homeseer phone settings are gone. This is inspite of the fact that I save them before shutting homeseer down. Clicked on save in bottom left corner.Fred
I didn't have a headset or phone plugged into my way2call when running test wizzard so didn't run all of the tests. I did successfully run the line test that took phone off hook, dialed digits, and hung phone up so should work with what we are trying to do here. Homeseer version is: 3.0.0.368. I will run your nee script soon and let you know the results. Thanks Much !!!!! Rick
That happened to me also a while back. Can't remember if the Way2Call settings were actually gone. Have you looked in the config folder at the hsphone.ini file? If I remember correctly, the file just wasn't being read at the Setup window.
Originally posted by Rick Bonari View PostAlso I noticed when I shut down homeseer and bring it back up all my homeseer phone settings are gone.Don
ITguyHS,
Yeah, the lattest script you sent me works great and I don't actually need a phone physically connected to way2call unit. Thank you, that is awesome work !!!!!! Still have issues with hsphone settings going away after shutting homeseer software down and restarting it? Again, the homeseer version is 3.0.0.368. Your thoughts on this are much appreciated !!!! I also added to the event to speak a message after script runs using speak action in event actions drop down. The message showed in the balloon in the lower right corner of the display but no speech. I am assuming that the hometroller S6 Pro has an internal speaker that the speech goes to. I looked in the speaker client setups and it is using speakers (HI-Phone Desktop USB). Not seeing any errors in log. Is "HI-Phone Desktop USB referring to the way2call unit or the hometroller S6 Pro? I haven't had a chance to check out text to speech or recognition but have at times heard the homeseer startup message. Your thoughts on this again are much appreciated !!!! You are awesome !!!!! Rick
Don Stephens,
Regarding the hsphone settings disappearing when restarting homeseer what would I be looking for in the hsphone.ini file? What was the final resolution? Thanks Much !!!!! RickLast edited by Rick Bonari; January 17, 2018, 06:24 PM.
I'm thinking that Don hit it right on the money regarding the settings. I seem to remember that happening with a past release. If you go into the settings and re-select the W2C, you might find that the settings are then displayed.Fred
ITguyHS,
That would make some sense as when you come back into homeseer you may want to change the modem selection to something other than way2call. Then what your saying is that with the modem select box blank you just need to reselect the way2call as modem device and hit enter or connect and then the rest of the original way2call settings will be displayed. I think this is what I hear you saying? Still not sure why the previous modem selection would be deleted when powering down homeseer and restarting. If you wanted to change your modem selection to something other than way2call you could just click on the dropdown box and select a different modem. Essentially when you go out of homeseer and come back in you have to reselect your modem selection and then the settings will be there as before. Seems like you shouldn't have to reselect way2call modem everytime your restart homeseer to get all your settings to show. Just wondering if I am clear on this and that what I am seeing is normal? Let me know if I am all wet and if there is actually a problem her. From what I hear you saying this is just normal and not a problem?
I tried selecting a different audio device in the speaker client setup and saved selection but still no sound. Do you have to actually not just restart homeseer software, but do you have to do a shutdown on the computer and restart for the changes to work? In the connection options, both connect local and connect auto are selected? The port is 10401 and user name and password are set to default.
Regarding the dialing issues you did a masterfull job on working for a solution that works and thanks much again. That was a major "to do" for me to check off !!! Now I just need to get my sound and speech recognition working. Thanks Again !!!!!!! RickLast edited by Rick Bonari; January 17, 2018, 11:42 PM.
ITguyHS,
Please see previous post also. I created an event to speak something and I tried plugging headset into headset jack on Hometroller S6 Pro and I get good speech in the headphones. How do I get the speech output to play through the hometroller internal speaker? I know it can do it as previously I have heard the homeseer startup message play through the hometroller speaker on power up. The forum other than you aren't much help. Thanks for your help and your patience !!!! Rick
Originally posted by Rick Bonari View PostThat would make some sense as when you come back into homeseer you may want to change the modem selection to something other than way2call. Then what your saying is that with the modem select box blank you just need to reselect the way2call as modem device and hit enter or connect and then the rest of the original way2call settings will be displayed. I think this is what I hear you saying? Still not sure why the previous modem selection would be deleted when powering down homeseer and restarting. If you wanted to change your modem selection to something other than way2call you could just click on the dropdown box and select a different modem. Essentially when you go out of homeseer and come back in you have to reselect your modem selection and then the settings will be there as before. Seems like you shouldn't have to reselect way2call modem everytime your restart homeseer to get all your settings to show. Just wondering if I am clear on this and that what I am seeing is normal? Let me know if I am all wet and if there is actually a problem her. From what I hear you saying this is just normal and not a problem?
Regarding the dialing issues you did a masterfull job on working for a solution that works and thanks much again. That was a major "to do" for me to check off !!! Now I just need to get my sound and speech recognition working. Thanks Again !!!!!!! RickFred
