seer + findings
    seer + findings
    I ran z-Seer + on my network and it has left me with a few questions that I am hoping someone can help me out with.
    I ran z-seer+ on a separate machine to hs3 and connected no problem via the IP address.
    1) When I select a node it doesn't show the path from the controller to that Node, even though this is listed in Node Information in HS3. It does show it's neighbours though.
    2) I ran the test all 4 times without altering anything and I got different results every time, 3 times I had different nodes showing pink, once I had all Nodes Green?
    3) I have a lot of Nodes with the return route of B=1
    4) the HS log has this entry every few minutes
    Z-Wave API Transmit Queue is not empty after waiting 20 seconds.
    I am wondering what is the correct order to tackle this I have optimised the network many times, When I check the node route on devices some seem to make unnecessary hops.
    Is the transmitter faulty/ some return path not making sense??
    thanks for all advice.
