w2k
HS1.7.30
I have a "not responding HS" with the following data just before the
"hang".
This has occured about every 3 -7 days in the last 3 weeks.
Any suggestions, I know the new version is coming out so if you have any "in the mean time suggestions" please ?
(is it the cnn script or weather.xml script... how could I debug or set HS to get "past" this issue. any others with same type issue?)
2/14/2005 6:34:23 AM~!~Event Trigger~!~Recurring Trigger (Weather XML this drives weather updates)
2/14/2005 6:34:53 AM~!~Error~!~Script error in file: weathercom_xml.txt: -
2147467259:The script was aborted because execution exceeded the specified timeout period. in line 745
2/14/2005 6:34:54 AM~!~Info~!~Scripts running: cnn_alert2.txt
(restart manual)
2/14/2005 7:00:26 AM~!~Info~!~HomeSeer version is: 1.7.30
2/14/2005 7:00:27 AM~!~startup~!~Loading configuration XML file
2/14/2005 7:00:38 AM~!~startup~!~Restoring device status
2/14/2005 7:00:38 AM~!~startup~!~Initializing text to speech
2/14/2005 7:00:43 AM~!~startup~!~Initializing X10 Interface
2/14/2005 7:00:47 AM~!~startup~!~Initializing Infrared Interface
2/14/2005 7:00:47 AM~!~startup~!~Initializing Z-Wave Interface
2/14/2005 7:00:47 AM~!~startup~!~Initializing scripting
2/14/2005 7:00:47 AM~!~startup~!~Initializing I/O
2/14/2005 7:00:47 AM~!~Web Agent Plugin~!~Register callback completed
END
HS1.7.30
"hang".
(restart manual)
END
