Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Jon00's plugins and scripts
Jon00's plugins and scripts Discussions related to Jon00's plugins and scripts.
  #81
Old April 24th, 2017, 04:40 AM
jon00's Avatar
jon00 jon00 is offline
Thumbs up Version 2 is now available
Version 2 of this script is now available.
A list of plugins is now automatically populated on a list and you can enable/disable these via standard Homeseer events.
Removing/adding plugins should have no effect on events set to control other plugins.
Whilst I have not fully resolved the multi-instance plugin issue, I'm happy to work with people to get this resolved.
There is currently full support for multi-instance plugins for:
  • Spud Plugins
Jon
  #82
Old May 8th, 2017, 01:27 PM
sparkman's Avatar
sparkman sparkman is offline
Hi Jon,
I've been trying v2 of this plugin and see a regular message in the logs:
Script Jon00Plugin.vben is currently running, waiting for it complete before its run again
I restarted my system on May 2nd and so far have seen that message 313 times. The script was run on restart, but has not been used since then to enable or disable plugins. Any ideas?
Al
  #83
Old May 8th, 2017, 01:45 PM
jon00's Avatar
Hi Al,
I had to use hs.RegisterStatusChangeCB in this new version so that changes in the lists are recorded. You must have a very active system as every call is immediately terminated (under 1ms) unless related to the script.
I'm sure you are aware that the device Scriptname/Scriptfunc has been broken for over a year so I could not use that.
  #84
Old May 8th, 2017, 03:01 PM
sparkman's Avatar
Originally Posted by jon00 View Post
Hi Al,
Thanks Jon, it's a pretty busy system, but not too crazy either. Would it make sense to allow multiple copies to run?
Al
  #85
Old May 8th, 2017, 03:48 PM
rprade's Avatar
rprade rprade is offline
I also have an active system and getting the same log entries. 793 since May 2. I didn't say anything about them and only realized how many by filtering on them.
Randy Prade
Aurora, CO
Prades.net
  #86
Old May 9th, 2017, 01:30 PM
jon00's Avatar
Al
When using hs.RegisterStatusChangeCB, it does allow multiple copies to run!
  #87
Old May 9th, 2017, 01:42 PM
rprade's Avatar
Is that something you have to embed in your script, or is there something we can change when it is called in startup?
  #88
Old May 9th, 2017, 11:30 PM
sparkman's Avatar
Thanks Jon, do you know why the error message is generated then? I assumed it was generated by HS3 if the script was already running when it was called again.
Al
  #89
Old May 10th, 2017, 05:22 PM
jon00's Avatar
I have no idea. Only HST can answer that one. Whilst it is annoying, I very much doubt it is putting additional strain on the system. There would not be an issue if the device Scriptname/Scriptfunc bug was fixed
It was discussed here: https://forums.homeseer.com/showthread.php?p=1274443
  #90
Old June 7th, 2017, 05:33 AM
zsima zsima is offline
Problem with enable/disable
Jon
Hi
I installed your enable/disable utility to see if it would help me with a problem I was having with a plugin that was freezing up.
The install was successful , but when I try to disable (or enable) a plugin either directly from the device created or from the event, nothing happens.
The log shows
"Jun-07 5:31:40 AM
Device Control
Device: Utility Jon00 Plugin Disable PI to Select Plugin (9) by/from: CAPI Control Handler
but the plugins are not enabled or disabled.
Anything I might be missing?
Any help appreciated
Zsima
  #91
Old June 7th, 2017, 11:39 AM
jon00's Avatar
Do you have local logins enabled?
  #92
Old June 7th, 2017, 11:52 AM
I have the following checked
No Password Required for Local/Same Network Login (Web Browser/HSTouch)
  #93
Old June 7th, 2017, 06:26 PM
jon00's Avatar
Can you try V1 which is also included in the download zip.
  #94
Old June 18th, 2017, 11:23 AM
Malosa's Avatar
Malosa Malosa is offline
Super Seer
v2 works great here just tested it.
HS3Pro 3.0.0.435 on windows 7 ultimate X64 on hp quadcore laptop 8 GB. 687 Devices, 480Events
  #95
Old September 4th, 2017, 12:31 PM
rprade's Avatar
Jon;
When HST made the HSTouch plug-in part of the core program they reformatted the plug-in management page. They put HSTouch (Built-In) at the top. As a result the top plug-in (Arduino here) becomes an amalgam of HSTouch and the top plug-in in your devices. The devices cannot enable or disable the top plug-in. Other than the top plug-in the rest seem to work fine. I'm on my iPad right now, so I will add some screenshots later.
  #96
Old September 4th, 2017, 12:39 PM
jon00's Avatar
OK.
Please make sure you are using the release version of the utility. I believe you are still using the pre-release version I sent you when testing.
  #97
Old September 4th, 2017, 03:41 PM
rprade's Avatar
OK.
I will download the release version and try it. Unfortunately, I did not bookmark your website, the link I found (http://www.jon00.me.uk/) do not resolve and it is no longer in your signature.
  #98
Old September 4th, 2017, 06:08 PM
jon00's Avatar
Must be something wrong at your end. I've had several guests in the last few hours and both my signature and URL posted work fine here.
  #99
Old September 4th, 2017, 08:05 PM
rprade's Avatar
It was on my end. Your IP range was blocked by one of the pfBlocker lists. I have white listed it and it resolves now. I'll try to figure out what list it was on.
The newly downloaded version2 stopped the Arduino plug-in from being mixed with HSTouch, above it on the list, but it is not there at all now.
  #100
Old September 5th, 2017, 05:30 AM
jon00's Avatar
I'll send you an email later today......
Tags
disable, enable, jon00, plug-in, plugin
