Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Jon00's plugins and scripts
Jon00's plugins and scripts Discussions related to Jon00's plugins and scripts.
  #101
Old September 10th, 2017, 03:41 AM
jon00's Avatar
jon00 jon00 is offline
V1.0.2 is now available. This corrects the bug introduced when HST integrated the HSTouch plug-in as part of the core program.
Jon
  #102
Old September 11th, 2017, 12:37 AM
Mr_Resistor Mr_Resistor is offline
I looked alover your site and couldn't find this. It's not appearing in "All" or "Updated" or "Latest"
what am I missing?
  #103
Old September 11th, 2017, 02:12 AM
jon00's Avatar
It is there! You can find it under 'all' or 'updated' or 'utility related' or the drop down at the top of the page. Look for: 'Jon00 Plugin Enable/Disable utility for Homeseer 3 (Version 1 and 2)'
  #104
Old September 11th, 2017, 06:11 AM
wadesready wadesready is offline
Thumbs up
Dude thanks for the excellent utility! without you, I would not be able to make the modbus plugin work and connect correctly with my midnite solar charge controller.
  #105
Old October 14th, 2017, 11:47 PM
abwyatt's Avatar
abwyatt abwyatt is offline
Hi Jon
I've just upgraded to Version 2 (V1.0.3). I am on the latest HS3 beta, 377.
Have followed the instruction manual. The script loads OK and creates 2 virtual devices as expected. But the plugins do not appear in the dropdown list. See attached screen grab. I have 12 plugins.
Any idea?
  #106
Old October 15th, 2017, 08:15 AM
abwyatt's Avatar
OK, I've got a bit of progress. I deleted the 2 virtual devices and rebooted. This recreated the devices and the drop down with all plugins are there now.
But selecting a plugin to disable it will hang the devices page. I can go to the Plugin page and observe the related plugin has not disabled. Nothing registers in the log. But I can't get back into the devices page without rebooting again.
  #107
Old October 15th, 2017, 12:05 PM
jon00's Avatar
I've just upgraded my test system to .377 and tried it here. Seems to work fine? Admittedly my test system only has 4 plugins but that should not make a difference.
  #108
Old October 16th, 2017, 02:42 AM
abwyatt's Avatar
I'm on mono 3.2.8. I've also got one multi-instance plugin, BLPlex. See screen grab.
Would that make a difference?
  #109
Old October 16th, 2017, 11:14 AM
jon00's Avatar
It should make no difference.
Please confirm you have local logins disabled which is a requirement.
  #110
Old October 16th, 2017, 11:40 AM
abwyatt's Avatar
You mean ticked or unticked? The manual says "Make sure you have 'No Password Required for Local Login' ticked under Setup". I have it ticked.
  #111
Old October 16th, 2017, 12:57 PM
jon00's Avatar
Yes that should be ticked. You should be able to browse your Homeseer web pages locally without needing to enter a password.
I'm currently out of ideas.
  #112
Old October 17th, 2017, 05:16 PM
rprade's Avatar
rprade rprade is offline
Jon;
It looks like I am in the same boat. The devices no longer are populated with plug-ins - they're completely empty. I don't know when it changed, because I verified they were working after you put the fix in for the changes when HSTouch was removed as a plug-in and added to the core program.
EDIT: Restarting HomeSeer repopulated the devices. I will see if I can figure out why/when they go away.
Randy Prade
Aurora, CO
Prades.net
  #113
Old October 18th, 2017, 12:38 AM
abwyatt's Avatar
Still not able to pin down the problem on my SEL, so I decided to test it on my backup Zee S2. The result is baffling.
The Zee S2 has been running fine with HS3 V368, and version one of your plugin. To test, I installed HS3 V377, and version 2 of the plugin. But when I tried to run the script, it errored out. Out of curiosity, I ran an existing event on the Zee S2 calling the version one script to disable a plugin, and was very surprised to find that it was working.
This is baffling since the copy of HS3 on the Zee S2 is an exact copy of my SEL since HS3 V368. Now, both have gone through the update to V377. Yet, neither version 1 or 2 work on the SEL now, and only version 1 will work on the Zee S2.
Baffled!
  #114
Old October 18th, 2017, 09:08 AM
abwyatt's Avatar
Are you able to disable and enable your plugins Randy? Are you on a Zee S2 or SEL?
  #115
Old October 22nd, 2017, 12:31 PM
jon00's Avatar
FYI, I just updated my Linux build to V379 and tested this without issue.
  #116
Old October 22nd, 2017, 12:47 PM
rprade's Avatar
It looks like Jon has tested on Linux with 3.0.0.379. Mine has been working properly since I posted above. HS3 is running under Windows 10 on a PC.
  #117
Old October 23rd, 2017, 08:43 AM
abwyatt's Avatar
I've updated to 379, but still the same outcomes on both my SEL and Zee S2.
On the SEL, neither script will work. The V2 script will create the 2 devices, but when I select a plugin from the drop down list, the HS3 device webpage interface just hangs.
On the Zee S2, the V2 script errors out, but the V1 script works
Here are the excerpts from the Zee S2 log showing the V1 and V2 scripts being manually run from an event.
Oct-23 7:31:22 PM Info Plugin CM15A with instance: has disconnected
Oct-23 7:31:22 PM Plug-In Shutting down Plug-In: CM15A
Oct-23 7:31:21 PM Event Running script in background: /usr/local/HomeSeer/scripts/Jon00PluginSet.vben("Main","CM15A;0")
Oct-23 7:31:21 PM Event Event Trigger "Testing Test Plugin Enabler - V1"
Oct-23 7:31:21 PM Event Event Testing Test Plugin Enabler - V1 triggered by the event page 'Run' button.
Oct-23 7:30:57 PM Error Compiling script /usr/local/HomeSeer/scripts/Jon00Plugin.vben: Cannot convert from 'System.Net.WebRequest' to 'System.Net.HttpWebRequest'.
Oct-23 7:30:57 PM Error Compiling script /usr/local/HomeSeer/scripts/Jon00Plugin.vben: The import 'System.Core' could not be found.
Oct-23 7:30:51 PM Event Running script in background: /usr/local/HomeSeer/scripts/Jon00Plugin.vben
Oct-23 7:30:51 PM Event Event Trigger "Testing Test Plugin Enabler - V2"
Oct-23 7:30:51 PM Event Event Testing Test Plugin Enabler - V2 triggered by the event page 'Run' button.
Here is my Zee S2 info ...
Current Date/Time: 10/23/2017 7:41:57 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.379
Linux version: Linux HomeTrollerZeeS2 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 17 Minutes 36 Seconds
IP Address: 192.168.100.189
Number of Devices: 334
Number of Events: 206
Available Threads: 399
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
Plugin Callback Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
  #118
Old October 23rd, 2017, 12:05 PM
jon00's Avatar
All I can think is that this is a mono 3.2.8 issue. I'm running Mono 4 on my Linux machine.
  #119
Old October 24th, 2017, 05:28 AM
abwyatt's Avatar
Yes, guess so. Not willing to upgrade Mono though. Not with 219 events to rebuild!
  #120
Old October 24th, 2017, 08:00 AM
Pete's Avatar
Pete Pete is offline
Maybe you can try the new Setup / Labs / Export to JSON / Import to JSON functions.
Maybe:
1 - create an image copy of your currently Zee2
2 - use the Export to JSON function
3 - shut down Homeseer
4 - update mono
5 - restart Homeseer
6 - import from JSON file
It might work. If it doesn't you can go back to your original SD card.
Last week here removed Mono 4.X and updated to Mono 5.2 and a couple of days later did an update which took mono to 5.4.
or
1 - Run the Windows HS3,
2 - import your stuff from the Linux build copy.
3 - Update Mono on your image copy build.
4 - Export the DB on your Windows test.
5 - Import the DB on your Linux build with Mono 4.X or Mono 5.X.
If you are using a backup SD card and this doesn't work you can go back to the original SD card.
Automator
Tags
disable, enable, jon00, plug-in, plugin
