Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Jon00's plugins and scripts
Jon00's plugins and scripts Discussions related to Jon00's plugins and scripts.
  #141
Old November 19th, 2017, 10:46 AM
wadesready wadesready is offline
Originally Posted by jon00 View Post
Looks fine...currently at a loss.
Damn...you would think, if it will run fine for 30 minutes, it should be good to go.... HS3 has been getting wacky ever since .363. .363 was crashing hard on me, so the tech told me to try upgrading to .383... with .363 your plugin worked, but HS crashed. with .383 your plugin crashes, but HS works, kinda...
  #142
Old November 19th, 2017, 11:17 AM
rprade's Avatar
rprade rprade is offline
Jon;
The error in my system always follows an event where the plugin devices are controlled, so it is only indicative that the devices are empty. After restarting this morning a couple of hours ago, the devices are still populated with plug-ins.
Nov-19 3:01:10 AM Jon00_Plugin Error in Main Block 3: System.Net.WebException: The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.GetResponse() at scriptcode6.VBWrapper.Main(String Parm)
Nov-19 3:01:00 AM Event Event Trigger "Utilities - Trouble Detection Z-Wave - restart plug-in"
Nov-17 3:23:10 PM Jon00_Plugin Error in Main Block 3: System.Net.WebException: The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.GetResponse() at scriptcode5.VBWrapper.Main(String Parm)
Nov-17 3:23:00 PM Event Event Trigger "Utilities - Misc Brultech Reset"
Nov-16 3:01:10 AM Jon00_Plugin Error in Main Block 3: System.Net.WebException: The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.GetResponse() at scriptcode7.VBWrapper.Main(String Parm)
Nov-16 3:01:00 AM Event Event Trigger "Utilities - Trouble Detection Z-Wave - restart plug-in"
I will attempt to find out what precedes their becoming empty. I don't know when it started behaving this way. I only found this problem a week ago and have been trying to get some idea as to when the devices become empty.
Randy Prade
Aurora, CO
Prades.net
  #143
Old November 19th, 2017, 12:38 PM
Originally Posted by rprade View Post
Jon;
Randy...on version .363 it worked fine, on .383 is when things went bad. something has changed in HS between the two versions
  #144
Old November 19th, 2017, 12:48 PM
rprade's Avatar
Possibly. I know Jon's script works fine after a restart. It is only after HS has been running for a while that the devices lose all of their VS pairs, but I don't know how long. My devices still look correct after restarting HomeSeer almost 4 hours ago. Here is a screenshot from just now
I went back to the HomeSeer database before I restarted this morning and the same device looked like this screenshot
  #145
Old November 20th, 2017, 09:44 AM
I downgraded to .362, which is the beta before the official release. And now everything is working fine. thanks Randy and Jon
  #146
Old November 20th, 2017, 10:12 AM
rprade's Avatar
24 hours later and both devices are still populated. HS V3.0.0.379.
  #147
Old November 20th, 2017, 07:38 PM
rprade's Avatar
I just restarted HomeSeer with v3.0.0.384 and the devices are not populated with any plug-ins. It seems this problem might occur at startup. It was also happening with v3.0.0.379.
  #148
Old November 20th, 2017, 07:53 PM
jon00's Avatar
jon00 jon00 is offline
Maybe something has changed at Startup which is not allowing things to be setup correctly. Perhaps running the script with an event after startup may work?
Jon
  #149
Old November 20th, 2017, 08:03 PM
rprade's Avatar
It is intermittent, because it survives a restart the bulk of the time. I can try running it from an event. I'll comment it out in startup and move it to my event that does housekeeping 2 minutes after startup.
  #150
Old November 20th, 2017, 10:12 PM
rprade's Avatar
Running it from an event works just fine. I wonder if the system is occasionally too busy at startup. The event I run it from has a 2 minute delay from startup.
I am currently running HS v3.0.0.387 as of today.
I will let you know if I see any problems.
  #151
Old November 20th, 2017, 10:59 PM
abwyatt's Avatar
abwyatt abwyatt is offline
I'm also seeing this on .382. Not starting with plugins populated, but running the script from an event populates the plugins. Also not sure how long they stay populated.
Intel NUC 7i5bnh/Kingmax 8GB/Transcend 32GB SSD | Lubuntu 16.04.3 64bit | Mono 5.8.0.108
HomeTroller SEL (Backup HomeSeer) | Lubuntu 16.04.3 64bit | Mono 5.8.0.108
HomeSeer: HS3 Standard, 3.0.0.418 | HSTouch enabled
Plugins: Z-Wave, CM15A, BLBackup, BLLAN, PHLocation, SDJ-Health, UltraLog3, EasyTrigger, Jon00VDGraphing, Jon00PluginSetV2, drhsEventEnabler, BLPlex, Chromecast, Device History
Smart Speakers: 2 X Google Home; 2 X Google Home Mini
Chromecasts: 4 X Chromecast 2
CCTV: Xeoma
  #152
Old November 20th, 2017, 11:30 PM
rprade's Avatar
While I don't know, I believe they will stay populated. I strongly suspect that the script has a problem at startup and never populates the devices, I don't think the VG pairs are being deleted during operation. It is possible that there may still be a problem even run from an event, but that still would only happen at startup.
Time will tell...
  #153
Old November 20th, 2017, 11:41 PM
Time will tell...
Randy on the event subject. How could you create an event to check to see if it is populated? that way if it fails it would just rerun the script and populate the fields.
  #154
Old November 21st, 2017, 12:02 AM
rprade's Avatar
I thought of that as well, but I have no idea how to check if the VS pairs are there. Someone familiar with scripting might be able to query the device to see if it returns any VG pairs. I don't know how to query a device for VS pairs.
It could be that some of the changes to the recent betas have delayed homeseer building the plug-in management page to the point where it is blank when the script runs from the startup script.
All that said, if delaying the running of the script cures it, there is no need for any other effort.
  #155
Old November 21st, 2017, 12:13 AM
On mine it seemed to always fill on startup but then failed later. sometimes one hour, 3 hours or even half a day.
  #156
Old December 25th, 2017, 08:29 AM
abwyatt's Avatar
Looks like on the latest HS3 beta 398, the script has become unusable. The plugin loads fine on boot and the dropbox is populated with the plugins. But anytime it runs, the following error occurs.
Error in Main Block 3: System.Net.WebException: The request timed out at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00049] in <50d80b08c1a5449282b22aedf03ce925>:0 at System.Net.HttpWebRequest.GetResponse () [0x0000e] in <50d80b08c1a5449282b22aedf03ce925>:0 at scriptcode2.VBWrapper.Main (System.String Parm) [0x00a48] in <098050fc276c4a5f84e9dc1213dcc4da>:0
  #157
Old December 25th, 2017, 09:18 AM
jon00's Avatar
Probably due to the introduction of SSL. This may be unrepairable.....
  #158
Old December 28th, 2017, 05:31 AM
jon00's Avatar
I've just tried this on 398 and it is working fine here......
  #159
Old December 28th, 2017, 05:39 AM
abwyatt's Avatar
Are you using SSL?
I was using SSL when the script was giving the error.
I've turned off SSL for 2 days and the script seems to be ok now.
  #160
Old December 28th, 2017, 05:48 AM
jon00's Avatar
No I'm not. Looks like that's the issue then.
I assume local browsing of Homeseer is also using SSL?
Tags
disable, enable, jon00, plug-in, plugin
