Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Jon00's plugins and scripts
Jon00's plugins and scripts Discussions related to Jon00's plugins and scripts.
  #161
Old January 20th, 2018, 05:05 AM
Blob Blob is offline
Manual IP select
Hi John,
Does the the v2 script also take a parameter for manual IP selection?
  #162
Old January 20th, 2018, 05:11 AM
jon00's Avatar
jon00 jon00 is offline
Originally Posted by Blob View Post
Hi John,
No. Why would that be necessary?
Jon
  #163
Old January 20th, 2018, 06:32 AM
Because my homeseer server has several IP's and only one is bound to Homeseer. Your script seems to autoselect the wrong one and is (i guess) therefor unable to login.
Error in Main Block 3: System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 192.168.x.x:80 at System.Net.Sockets.Socket.DoConnect(EndPoint
In the V1 script there is a parameter to manually select the correct IP and works like a charm. e.g. <plugin name>;0;192.168.y.x
Maybe also helpfull:
hs.GetINISetting ("Settings", "gServerAddressBind", "", "settings.ini") -> correct IP address
hs.GetIPAddress -> wrong IP address
  #164
Old January 20th, 2018, 07:20 AM
jon00's Avatar
OK, I can add a manual IP entry. Stand by.....
  #165
Old January 20th, 2018, 07:48 AM
jon00's Avatar
Try V1.0.3 on my site.
You should already have Jon00Plugin.ini in your config directory.
Just add the following:
[Settings]
HS3HostIP=XXX.XXX.XXX.XXX
This will override the automatic IP detection settings.
  #166
Old January 20th, 2018, 08:42 AM
[Settings]
Wow, that was quick.
And most important. It works perfectly.
Thanks John.
  #167
Old February 19th, 2018, 04:10 PM
MdeMan's Avatar
MdeMan MdeMan is offline
I must be doing wrong if I manually use the devices for enabling/disabling the utility works but if I try automatically in a script I get this and it locks up hs3:
Feb-19 1:55:43 PM Error Displaying remotely connected interfaces: Object reference not set to an instance of an object.
Feb-19 1:54:46 PM Error Initializing plug-ins Phase 2 Exception: Object reference not set to an instance of an object.
Feb-19 1:47:53 PM Jon00Plugin Enabling Plugin: MediaController [See plug-in config]
Feb-19 1:47:53 PM Jon00_Plugin Error in Main Block 3: System.Net.WebException: The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.GetResponse() at scriptcode1.VBWrapper.Main(String Parm)
Marcel
  #168
Old February 19th, 2018, 07:09 PM
jon00's Avatar
Under Setup/Network tab, do you have 'No Password Required for Local/Same Network Login (Web Browser/HSTouch)' ticked?
  #169
Old February 19th, 2018, 07:25 PM
MdeMan's Avatar
Yes I have.
Marcel
  #170
Old February 19th, 2018, 07:38 PM
jon00's Avatar
Try this.
In the Jon00Plugin.ini file (found in your Config folder), add the following entry under [Settings]
HS3HostIP=129.168.1.29
(Change 129.168.1.29 to your Homeseer IP address)
You may need to add the [Settings] entry as well.
Does that work now?
  #171
Old February 20th, 2018, 09:38 AM
MdeMan's Avatar
Hi Jon,
I have something weird going on because sometimes it works and sometimes it doesn't. It seems to always work when I use the devices directly from the homeseer web page.
Please allow me some time to investigate. I'm dealing with a lot of issues that appeared after the last windows 10 update.
Marcel
  #172
Old February 21st, 2018, 09:30 AM
MdeMan's Avatar
Okay we can delete this post. Other issues caused this not to be working. This issue happened because the plugin was unresponsive while I was trying to restart it.
Under normal circumstances the script works now.
Marcel
  #173
Old April 7th, 2018, 03:52 PM
andlan andlan is offline
Originally Posted by wadesready View Post
On mine it seemed to always fill on startup but then failed later. sometimes one hour, 3 hours or even half a day.
I also have a problem with this.
It populates at startup but evetually all plugins disapear from the dropdown.
When I try to run the script i get this error message:
Error in Main Block 3: System.Net.WebException: The request timed out at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) <0x7234bb80 + 0x00158> in :0 at System.Net.HttpWebRequest.GetResponse () <0x7234a3d0 + 0x00067> in :0 at scriptcode2.VBWrapper.Main (System.String Parm) <0x705d1ee0 + 0x02327> in :0
Restart HS and it works just fine for some time, and then i crashes again.
I am running HS3 3.0.0.368 on linux, and no SSL.
  #174
Old April 10th, 2018, 10:09 AM
jon00's Avatar
Apologies, I missed this.
All I can think it is a Mono issue. The error relates to being unable to read the plugins page. I cannot see how this can deteriorate over time. I assume you allow local logins without a password?
  #175
Old April 10th, 2018, 10:38 AM
It might be that the time issue is actually the number of times the script tries to disable/enable plugins, ie. the 2nd or 3rd time. I'll double check this.
And yes local logins are allowed without password.
  #176
Old April 10th, 2018, 11:02 AM
jon00's Avatar
So how often are you disabling/enabling plugins then?
  #177
Old April 10th, 2018, 11:09 AM
usually 1-2 times a day occasionally 3 times
I tested som scenarios just now, and it seems to fail the 2nd time I try to disable the plugin.
My test scenarios is as following:
scenario 1: Disable plugin1: ok, enable plugin1: ok, disable plugin1: fail
scenario 2: Disable plugin1: ok, disable plugin2: ok, enable plugin1: ok, enable plugin2: ok, disable plugin1 OR 2: fail
and tested more scenarios like this in multiple different orders.
  #178
Old April 10th, 2018, 12:58 PM
jon00's Avatar
I don't have an answer to this. For some reason the script is unable to load Homeseer's plugin page and you are getting the Page timeout error.
Get it to error and then try and access the Homeseer plugins page via a browser. If you succeed, then try disabling/enabling a plugin again.
  #179
Old April 10th, 2018, 01:08 PM
Got it to error, browsed to plugin page and manually disable/enable plugins worked like a charm.
Then I tried to manually run script, and got the same error.
  #180
Old April 10th, 2018, 01:31 PM
jon00's Avatar
I'm at a loss then. I have it here on HS3 Linux running Ubuntu 16.04 and it works fine with repeated enabling/disabling of the same plugin.
Tags
disable, enable, jon00, plug-in, plugin
