We have released a HS3 beta version 3.0.0.332 with some major changes, so we are looking for testers.
This version has moved the HSTouch Server plugin functionality into HS3, so the plugin is no longer used and will not be loaded (even if the file exists). This change was made primarily so we could expose the cameras to our JSON API in a future update. It also does the following:
* Speeds up client access, including camera viewing
* Frees up a plugin slot on the Zee S2 so an extra plugin can be loaded
Please post if you see any issues.
