Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > EasyTrigger Plug-In (3P)
EasyTrigger Plug-In (3P) Discussions related to the EasyTrigger plugin by SPUD.
Old November 14th, 2017, 04:52 PM
ryanoly ryanoly is offline
Device string changes and becomes empty
How do I do empty string or null or void or whatever you call it?
Trying to detect when the string value of a device becomes empty and I'm not having any luck.
Old November 14th, 2017, 05:01 PM
spud's Avatar
spud spud is offline
Moderator
that's a good question...
I don't think this is possible, because the string triggers/conditions expect a non empty parameter to be considered valid.
Old November 14th, 2017, 05:04 PM
Thanks for the quick reply guess I can do 26 "and" statements
where string does not contain a
where string does not contain b
where string does not contain c
Can I use any functions to make the easier than a bunch of "and does not contains"
Old November 14th, 2017, 05:09 PM
spud's Avatar
Moderator
I don't think so, sorry
Old February 17th, 2018, 09:10 PM
teladog01 teladog01 is offline
Hi guys. I've run into this problem tonight...trying to detect when the string is empty. Did anyone come up with a way to do this?
Old February 18th, 2018, 04:20 PM
spud's Avatar
Moderator
I will add a way to check for empty string
Old February 19th, 2018, 06:37 PM
spud's Avatar
Moderator
In version 3.0.0.44 (available in the Beta section of the updater) empty string is now allowed for string triggers and conditions
Old February 19th, 2018, 06:49 PM
Awesome! I will check it out. Thanks for adding...
Error: Z-Wave device has empty ROOT object mikee123 HS3 / HS3PRO Discussion 3 February 10th, 2018 01:17 PM
Insteon Special Triggers Device Drop-down is empty tpchristian Insteon Plug-in (Mark Sandler) 2 January 18th, 2016 08:58 PM
How to Parse device string and create device values dhellis Script & Plug-In Development 6 October 8th, 2012 02:41 PM
Returning an Empty String From a Function MarkHargrove HSTouch™ 9 June 4th, 2011 12:25 PM
empty device names for ca9000 and hsm100 ksdehoff HSM100™ Multi-Sensor 6 October 23rd, 2008 06:53 AM
