Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > Tasker Plugin (3P)
Tasker Plugin (3P) Discussions related to the Tasker plugin by Tonlof.
Old January 22nd, 2018, 09:29 PM
simonmason's Avatar
simonmason simonmason is offline
Is there anyway to get rid of the Tasker Connection Errors?
Everytime I issue a command I am getting the following error messages, yet everything is working fine. I recall seeing a thread at one point that this is normal? Is it normal or is there something else going on here that I should be concerned with. Thanks.
Jan-22 8:26:22 PM Tasker Plugin Error ----------------------------------------------------------------------
Jan-22 8:26:22 PM Tasker Plugin Error Connection Error
Jan-22 8:26:22 PM Tasker Plugin Error Sending local command failed: ()
Old January 23rd, 2018, 02:42 PM
tonlof's Avatar
tonlof tonlof is offline
Hi, you probably have local ip and the phone does not respond on the local wifi request and use the cloud service instead. So no issue actually, if you only want cloud connection, try to remove the local ip.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old January 23rd, 2018, 05:52 PM
simonmason's Avatar
The local IP is removed - the field is blank.
The device I am trying to control is on the local network so should I put it's IP address in?
Old January 23rd, 2018, 06:36 PM
tonlof's Avatar
It will always use cloud service if the android ip is not responding.
You can check from any browser in your network to see if your device is listening for local commands by browsing to http://192.168.x.x:1817/?message=null
If you see a json data string it works but if the phone is sleeping or doing something else it may not respond so test it several times with black screen / keylock etc.
Old January 24th, 2018, 10:03 AM
simonmason's Avatar
Great thanks. I put the local IP in as it is mounted on the wall and will never leave the house.
Old February 18th, 2018, 05:07 PM
simonmason's Avatar
I did make the changes below and I am still getting the errors? Tasker is working as far as I can tell. I just want to make sure I am not doing something wrong. Thanks.
Old February 18th, 2018, 08:15 PM
Eman Eman is offline
What do you get when you put 192.168.2.90 for the IP ?
You can copy and paste.
Eman.
Old February 18th, 2018, 09:11 PM
simonmason's Avatar
I get the same error with 192.168.2.90.
i get the following when I try : http://192.168.2.90:1817/?message=null
{"communication_base_params":{"type":"ResponseBasic","fallba ck":false},"sender":"APA91b_Key_deleted_byTonlof","result":" OK"}
Old February 19th, 2018, 02:01 PM
tonlof's Avatar
What I can see is that you don't have any dots in your IP address.
Old February 19th, 2018, 03:07 PM
simonmason's Avatar
Did you see my other post? I tried with and without dots. Thanks
Old February 19th, 2018, 04:52 PM
tonlof's Avatar
Sorry, I missed that.
You may test attached plugin, don't forget to make a full backup off homeseer.
Old February 25th, 2018, 09:37 AM
simonmason's Avatar
Thanks - this version seems to have eliminated the errors in the log.
Local LAN connection from Tasker plugin to autoremote tonlof Tasker Plugin (3P) 1 November 3rd, 2015 06:05 PM
Client connection errors Bestgear HSTouch™ 7 February 17th, 2010 09:09 AM
New Client Connection errors darren-mc Bluetooth Connector 3 March 23rd, 2009 08:19 PM
Connection Errors darren-mc HSVistaGadget Plug-In 6 November 16th, 2008 05:03 PM
New AAG connection and a couple of errors? sbessel MCS Temperature 11 February 2nd, 2004 11:33 PM
