Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > JowiHue Plug-In
JowiHue Plug-In Discussion area for JowiHue plug-in by W.Vuyk
Old February 19th, 2018, 04:12 PM
Michelob Michelob is offline
Seer Plus
Aqara wired wall switch (double)
Hello,
Good news. This switch, that was already recognized by deCONZ, is now seen into Jowihue :
https://www.gearbest.com/alarm-systems/pp_610096.html
Pressing (physically) the buttons gives :
- left 1 time = 4002
- left 2 times : nothing
- left 3 times = 1002
- right 1 time = 5002
- right 2 times : nothing
- right 3 times = 2002
- both simultaneously = 3002
As these are values manually entered, I've tried to set them from another device, but the HS EVENTS doens'nt show them yet.
Anyway, it's cool.
Michel
Old February 19th, 2018, 06:22 PM
w.vuyk's Avatar
w.vuyk w.vuyk is offline
Michel,
Could you send me the details of the Properties/JowiHue tab, especially the json part on that tab? I would like to check if it could be added to the xml file as well. The plugin recognises a lot of devices already (purpose of this beta), but still feel the need to refine here
Wim
-- Wim
Plugins:RFXCOM, HSTouch Server, Squeezebox, BLGData, Restart, Jon00's Perfmon and Network monitor, WeatherXML, BLBackup, TenScripting, BC4, Pushover, PHLocation, JowiHue, Zwave, Sonos
650 devices ---- 336 events ----- 40 scripts
Old February 20th, 2018, 07:00 AM
Seer Plus
Hello Wim,
Do you mean this ?
ZHASwitch
**************************** Object info *****************************
"ep": 2,
"etag": "5ce7b493302cec6e062bd9b97d739499",
"mode": 1,
"state": {
"daylight": null,
"buttonevent": 3002,
"status": null,
"flag": null,
"humidity": null,
"temperature": null,
"presence": null,
"open": null,
"lastupdated": "2018-02-20T10:42:21",
"lightlevel": null,
"dark": null,
"lux": null,
"pressure": null
"config": {
"long": null,
"on": true,
"alert": null,
"battery": null,
"configured": null,
"duration": null,
"lat": null,
"ledindication": null,
"pending": null,
"reachable": true,
"sensitivity": null,
"sensitivitymax": null,
"sunriseoffset": null,
"sunsetoffset": null,
"tholddark": null,
"tholdoffset": null,
"url": null,
"usertest": null
"name": "lumi.ctrl_neutral2",
"type": "ZHASwitch",
"modelid": "lumi.ctrl_neutral2",
"productid": null,
"manufacturername": "LUMI",
"swversion": null,
"uniqueid": "00:15:8d:00:01:f5:0f:a4-02-0006"
************************* End Object info ***************************
Old February 20th, 2018, 07:28 AM
w.vuyk's Avatar
Michel,
That is the one. I have updated the xml with the new info. There is still a bit of ongoing discussion on the github about the values. I think they have changed it with the latest version of deCONZ, so I used the values I found there for it.
I am planning to submit the new beta soon, so if you want to test it, make sure to have the latest bet of deCONZ as well. Press the refresh device values on the device properties/JowiHue tab after the tables have been updated.
Wim
Old February 20th, 2018, 07:41 AM
Seer Plus
Thank you Wim, I'll do that as soon as you edit the new Beta.
HTML code is On
Aqara Magic Cube ldplusse JowiHue Plug-In 15 February 13th, 2018 04:55 PM
Wired Wall Switches now reporting as if battery devices TimSRQ HomeSeer Z-Wave Plug-in 2 January 5th, 2017 01:22 AM
Double pole switch UK IanIreland Lighting & Primary Technology Discussion 9 October 2nd, 2013 12:48 AM
Double Tap on Insteon Switch mbrett ISY Plug-in Beta (3P) 4 March 21st, 2011 02:46 PM
Which z-wave switch and how wired? kenflorian HomeSeer Z-Wave Plug-in 9 May 28th, 2007 03:27 PM
