Lost Connection to all Z-Wave Nodes
    I recently partially lost a connection to my Z-Wave Nodes. I can turn things on/off, but usually need to send multiple commands before the device responds. Multiple brands of lights switches/sensors. If I turn on a light, it doesn't say it's ON, it shows device unknown. If I try to do an Optimize, I get every node saying: "Done. The optimization was not executed as the node cannot be reached." However, return paths are shown. Even nodes that are 10 feet away from my Z-Wave controller Z-troller).
    Everything was working fine until about 2 weeks ago. Recently updated HS3, but no new devices added or other changes.
    If I go to a specific device and audit the node or test connectivity, it fails. But I still get occasional updates and I can turn devices on/off (just not responding well).
    Any ideas? Have restarted everything multiple times - here's my startup log:
    3/24/2016 11:01:21 AM ~!~Startup~!~Settings Loaded.
    3/24/2016 11:01:26 AM ~!~Startup~!~
    3/24/2016 11:01:26 AM ~!~Startup~!~*********************************************** *********************************
    3/24/2016 11:01:26 AM ~!~Startup~!~ HomeSeer version 3.0.0.258 Edition: HS3 Pro Starting Now
    3/24/2016 11:01:27 AM ~!~Startup~!~Creating Class Objects...
    3/24/2016 11:01:27 AM ~!~Startup~!~COM port classes started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Application interface class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Web server class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~E-Mail SEND class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~E-Mail RECEIVE class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Plug-In Interface class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~HSPhone external interface class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Local voice recognition class started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Database SAVE process started.
    3/24/2016 11:01:27 AM ~!~Startup~!~Loading configuration file ...
    3/24/2016 11:01:27 AM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files\HomeSeer HS3\Data\Clark Party House_converted.hsd
    3/24/2016 11:01:28 AM ~!~Database~!~Loading Devices...
    3/24/2016 11:01:28 AM ~!~Load Config~!~91 total devices loaded.
    3/24/2016 11:01:28 AM ~!~Load Config~!~Loading Event Groups...
    3/24/2016 11:01:28 AM ~!~Load Config~!~Loading Events...
    3/24/2016 11:01:28 AM ~!~Error~!~DeSerializing object (byte): There was an error deserializing the OrderedDictionary. The ArrayList does not contain DictionaryEntries. Source=System
    3/24/2016 11:01:28 AM ~!~Load Config~!~37 total events loaded.
    3/24/2016 11:01:28 AM ~!~Load Config~!~Loading COUNTERS...
    3/24/2016 11:01:28 AM ~!~Load Config~!~Loading TIMERS...
    3/24/2016 11:01:28 AM ~!~Startup~!~HomeSeer version is: 3.0.0.258
    3/24/2016 11:01:28 AM ~!~Startup~!~Creating Speaker Client Interface Object...
    3/24/2016 11:01:28 AM ~!~Startup~!~This version of HomeSeer is registered as a HS3PRO version.
    3/24/2016 11:01:29 AM ~!~Info~!~Remote plug-in API interface started on port 10400
    3/24/2016 11:01:29 AM ~!~Startup~!~Checking for available plug-ins
    3/24/2016 11:01:29 AM ~!~Plug-In~!~Found plug-in: HSTouch Server, version: 3.0.0.75
    3/24/2016 11:01:30 AM ~!~Plug-In~!~Found plug-in: RFXCOM, version: 30.0.0.29
    3/24/2016 11:01:31 AM ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.1.25
    3/24/2016 11:01:31 AM ~!~Startup~!~Initializing Plug-Ins
    3/24/2016 11:01:32 AM ~!~Info~!~Plugin HSTouch Server has connected. IP:127.0.0.1:1041
    3/24/2016 11:01:32 AM ~!~Plug-In~!~Finished initializing plug-in HSTouch Server
    3/24/2016 11:01:35 AM ~!~Info~!~Plugin RFXCOM has connected. IP:127.0.0.1:1053
    3/24/2016 11:01:37 AM ~!~RFXCOM~!~29 (InitIO) RFXCOM version is:30.0.0.29
    3/24/2016 11:01:40 AM ~!~RFXCOM~!~29 (InitTRX) Connect Transceiver #1 on COM9
    3/24/2016 11:01:40 AM ~!~Plug-In~!~Finished initializing plug-in RFXCOM
    3/24/2016 11:01:43 AM ~!~Info~!~Plugin Z-Wave has connected. IP:127.0.0.1:1070
    3/24/2016 11:01:43 AM ~!~Z-Wave~!~InitIO called, plug-in version 3.0.1.25 is being initialized...
    3/24/2016 11:01:43 AM ~!~Z-Wave~!~Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
    3/24/2016 11:01:45 AM ~!~Z-Wave~!~Loading Z-Wave Network Objects...
    3/24/2016 11:01:45 AM ~!~Z-Wave~!~1 total Z-Wave Network Objects loaded.
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~Loading Z-Wave Data Objects...
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~1 Networks were restored from the data in the database... Building data connections.
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~Network 003D1D00 has 78 device data elements.
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~78 total Z-Wave Data Objects loaded.
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~0 event triggers were loaded from HomeSeer.
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~0 event actions were loaded from HomeSeer.
    3/24/2016 11:01:46 AM ~!~Plug-In~!~Finished initializing plug-in Z-Wave
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~Z-Wave Remote: ============================================================ ==========
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~Z-Wave Remote: ----------------------------------------------------------------------
    3/24/2016 11:01:46 AM ~!~Z-Wave~!~Initializing Z-Wave interface Z-Wave Remote (HomeSeer Z-Troller) on COM1
    3/24/2016 11:01:47 AM ~!~Z-Wave~!~Z-Wave Remote: The Z-Wave Command Execution Thread was Started or Restarted.
    3/24/2016 11:02:00 AM ~!~Z-Wave~!~Z-Wave Remote: The Z-Wave API Execution Thread was Started or Restarted.
    3/24/2016 11:02:00 AM ~!~Z-Wave~!~Z-Wave Remote: Getting node information from controller...
    3/24/2016 11:02:00 AM ~!~Z-Wave~!~Z-Wave Remote: Controller Manufacturer: UNKNOWN, ID=0xFF, Type=0x8
    3/24/2016 11:02:00 AM ~!~Z-Wave~!~Z-Wave Remote: Controller firmware version: 0.191
    3/24/2016 11:02:01 AM ~!~Web Server~!~Local IP address (subnet) is: 192.168.0.130 (255.255.255.0)
    3/24/2016 11:02:01 AM ~!~Web Server~!~UPNP Discovery started
    3/24/2016 11:02:01 AM ~!~Web Server~!~Web Server started on port 80
    3/24/2016 11:02:02 AM ~!~Startup~!~Creating ASP.NET application host...
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Z-Wave Serial API version: 4
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Z-Wave interface node ID: 1, Home ID: 003D1D00
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Found 25 Z-Wave nodes in interface node ID 1 (Z-Wave Remote)
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Z-Wave PC Controller Library Version: Z-Wave 3.28 (ZDK 5.03)
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: Z-Wave PC Controller is Type: Installer
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: ............................................................ ..........
    3/24/2016 11:02:02 AM ~!~Z-Wave~!~Z-Wave Remote: .............................. FINISHED ..............................
    3/24/2016 11:02:05 AM ~!~Z-Wave~!~***************************************************** **************************
    3/24/2016 11:02:06 AM ~!~Z-Wave~!~ STARTUP COMPLETE: All configured interfaces were successfully initialized.
    3/24/2016 11:02:06 AM ~!~Z-Wave~!~***************************************************** **************************
    3/24/2016 11:02:12 AM ~!~Startup~!~Start automation engine...
    3/24/2016 11:02:12 AM ~!~Startup~!~Initializing Speaker Client Interface
    3/24/2016 11:02:12 AM ~!~Speech~!~Listening for remote speaker connections on port 10401
    3/24/2016 11:02:13 AM ~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files\HomeSeer HS3\Data\Energy\Energy.hsd
    3/24/2016 11:02:14 AM ~!~Startup~!~Updater services starting...
    3/24/2016 11:02:14 AM ~!~Startup~!~Starting DDNS service...
    3/24/2016 11:02:14 AM ~!~Info~!~Starting speaker client...
    Have you tried to restart the ZWave interface and/or HomeSeer3 ?
    What ZWave controller are you using?
    Nicolai L
      Z-Troller. Is it possible it's being flaky/failing? I hate to buy a new one just on a whim...
        I've restarted everything multiple times.
          Do you have batteries in it? If so unplug it from power and pull the batteries out then reconnect it leaving the batteries out and see if that helps.
          Jeff
            will try tonight - thank you.
              That worked great. As soon as I removed the batteries and reset it, everything started working great, all nodes could be reached and respond. Thanks for the help. Now put the batteries back in and enjoy again...
                You will find several posts about leaving the batteries out and you will have less problems. In fact I think HS suggests leaving them out. I always ran them with the batteries in, but I will say it was one of my worst troubleshooting experiences because I couldn't figure out what was going on and turned out I just needed to leave them out and unpowered for a few minutes. I no longer use my ztrollers, but did 99% of the time have the batteries in. So you might try it again with the batteries, but if you run into issues with it again try running for a while with the batteries out and see if that cures the problem.
                Jeff
