Has anyone messed around with calibrating the Multisensor 6? There's something about using an Excel Spreadsheet to get the Hex parameter, and entering that into one of the parameters.
Aeotec Multisensor 6 Temp Calibration
Originally posted by tome10 View PostHas anyone messed around with calibrating the Multisensor 6? There's something about using an Excel Spreadsheet to get the Hex parameter, and entering that into one of the parameters.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I use my own script which writes a corrected value to a virtual device. However, I have perhaps 10 of these sensors and have noticed that these sensors are very inaccurate and not linear. When the sensor is cold or hot, their temperature readings can vary by 10 to 20 degrees from actual. They do better around 'comfort zone' temps. If direct sun hits them, they can read 110 on an 80 degree day.
I'd like to find an accurate, linear and cheap z-wave temperature sensor.
- Robert
