Old April 5th, 2013, 02:20 PM
michaeldr michaeldr is offline
Accessing Homeseer through bridge (internal network)
I have a linksys router. Homeseer is sitting on a Win7 PC at 192.168.1.55
If I connect to the router (wireless or wired) with any computer on my home network, I can type in a browser that ip address and get to the homeseer start page without issue.
However, I also have a WUMC170 wireless bridge. Any computer attached to the bridge works on the internet great. However, most of the time (but has on occasion) it will not connect to Homeseer (again by typing 192.168.1.55).
If I take that same computer and move it to the router (bypassing the bridge), everything works great.
I assume the bridge is not passing certain ports or protocols. Anyone have any ideas?
Old April 5th, 2013, 03:13 PM
dcorsus dcorsus is offline
Is the WUMC170 a wireless access point (no routing) or a wireless router? If the latter, turn off DHCP on the wireless router and hook up the router to your bridge, not by it's WAN interface but the LAN interface. As such it all stays in the same L2 network and L3 subnet. No port translation issues, broadcast domain is your complete network ...
Dirk
Old April 5th, 2013, 03:40 PM
kaldoon's Avatar
kaldoon kaldoon is offline
Are you talking Linksys WUMC710 Wireless-AC Universal Media Connector? This device should pass all traffic your router will allows
Old April 5th, 2013, 03:45 PM
Yes, and yes it should. But it isn't. I though maybe it was having an issue with a port.
Old April 5th, 2013, 03:46 PM
Dirk
It is just an access point. So it shouldn't be hanging any of it up.
Old April 5th, 2013, 04:21 PM
I agree, couldn't find what type of device it was.
One more item I can think of is MAC learning and MAC spoofing. Does it happen when you move the device from wireless to wired or from one port to another? Switches learn MAC addresses and forward your traffic to a port it has learned your MAC address on. When a device moves between ports you could briefly experience some issues.
Just thinking outside the box
Dirk
Old April 5th, 2013, 05:54 PM
I will try and dig into the DHCP table and see if maybe the Mac address are messed up. I will probably try rebooting everything this weekend. Just never know what won't come back up right.
Old April 5th, 2013, 05:56 PM
One other thing I noticed. In the Homeseer log it does see the user (from behind the bridge) successfully logged in. Just nothing ever makes it back to that computer.
Old April 5th, 2013, 06:37 PM
Pete's Avatar
Pete Pete is offline
Personally to save you a bit of grief I would reset / cold button the Linksys WUMC710 Wireless-AC Universal Media Connector. Then do whatever configuration you need to do on it and try again.
From the manual:
Reset (on bottom) There are two ways to reset the media connector’s factory defaults. Either press and
hold the Reset button for approximately five seconds, or restore the defaults from Administration > Factory
Defaults in the media connector’s browser-basedutility. The Reset button is located on the bottom.
There isn't much to the manual guide:
http://downloads.linksys.com/downloa...B_EN_Web,0.pdf
Other than MAC filtering, Wireless configuration and whether it is using DHCP or a static address; there isn't much more. It should work just fine. I think that the bridging piece is the wireless devices needing a gateway. Thinking the ports are just direct connects to whatever.
You can try to ping the Homeseer box via the Linksys to see if it is getting there. Make sure too that all of your devices have the same subnet mask and gateway and DNS. I would also suggest configuring the box with a static IP verus a DHCP setup.
Here I was testing a new table tablet with wireless and HSTouch. I noticed it kept dropping and reconnecting. Checking the interface I noticed that power saving was enabled on the wireless interface. I disabled the power saving and all is well again.
Automator
Old April 5th, 2013, 07:03 PM
Thank you for your responses. I will dig into it a little further this weekend. I am also waiting on Level 2 tech support from Lynksys.
Does anyone know what ports homeseer would use. As it is sending everything by http I would suspect 80.
Old April 5th, 2013, 07:35 PM
donstephens's Avatar
donstephens donstephens is online now
Port 80 is the default. You can change it in the setup > web server > server port.
Don
Old April 6th, 2013, 03:17 AM
mhn mhn is offline
To me it sounds like return route.
If your wireless acces point is on another network, do your 192.168.1.x network know where to send the return traffic?
If there are no route, the answer will go to the internet (default gate.)
As said before the easy way to set it up is to make sure everything are on the same net.
Regards
Morten
Tags
ports, wireless bridge, wumc170
