Go Back   HomeSeer Message Board > General Home Automation > Off Topic
Off Topic Post your jokes, funny stories, current events and antecdotes here.
Old July 21st, 2017, 10:27 AM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
my 4th of july
So my profile pic shows my truck in cartoon mode..
thought id show you what the truck looked like on 4th of july...
fyi my bumper is waste height...
HS - HS3 Pro Edition 3.0.0.368
Plugins - BLLAN 2.0.38.0 | BLRF 2.0.93.0 | Concord 4 3.1.13.8 | HSTouch Server 3.0.0.68 | RFXCOM 30.0.0.36 | X10 3.0.0.36 | Z-Wave 3.0.1.150
Old July 21st, 2017, 10:29 AM
oh and truck broke where it is.. not sure how this happened or why... firewall is almost touching the dizzy but all cab bolts are tight (verified) so didn't know this was the issue..
5h to get out..
humiliation - pulled out by 2 huge ford diesels and 1 large big block ford
I had the part on hand but didn't know that was the issue...
so got pulled home by the big block ford (friend)
so insult sprinkled on the humiliation...
Old July 21st, 2017, 10:33 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Ha! That is awesome!
Old July 21st, 2017, 10:52 AM
Rupp's Avatar
Rupp Rupp is offline
Bummer! Those Fords pulling your out and home had to hurt Was the distributor cap damaged to cause this damage to the rotor?
-Rupp
Old July 21st, 2017, 11:11 AM
no that is the weird part...
I got stuck.. rolled window down and told bud to pull me out.. he laughed and said... NOPE YOU DIDNT TRY YET...
so back in gear I went.. forward and reverse sending mud 20' in the air.. totally submerging my truck and sinking to the axles... in front of drivers side is about 4.5 feet as the axle is hung up and the mud is deeper... I turned the truck off... rolled window down and asked if that was good enough...
he then said.. yup yer stuck.. lets get you out of there...
I go to crank it over and it wouldn't start...
but I found out later that a truck on 54's.. YES 54's!!!! buried himself there so if I would of gone any farther I woulda lost the entire front of my truck and most likely ruining my motor!!!!!
but getting back to what you asked.. nope... cap was still on just fine and I didn't think of checking that. I carry a spare cap/rotor/coil/plugs/wires so I coulda been pulled out, replaced rotor.... few donuts and drive home... hah
it could only be one of 2 things...
1. I (like a dummy) shut the truck off.. I knew my exhaust was out of the water; however, I totally forgot the exhaust isn't a single piece thus water actually filled the drivers side pipe and creating back pressure not allowing the truck to start.... that wouldn't hurt this though...
2. hit hole... cab moved forward a smidge (as firewall is touching it) and pushed cap a bit and rotor go bang, bang, bang as it went around and wasn't fully broke yet... then after shutoff it broke the rest of the way...
this weekend I'm planning on taking the cap off and looking... to see if it has rub marks...
I'm ticked as I don't like being stuck. my thing is, I should be able to get out no matter what...
so I have started my planning...
I own a hi-lift jack but didn't have it on me.. but I will be mounting it to the truck in a few weeks after my algebra exam next thurs then vacation...
I have also bought one of these...
http://www.hi-lift.com/accessories/lift-mate.html
then I am planning on taking 5 2x12's that are 4' in length and mounting them in the truck....
so future.. I can jack myself up and put the boards under it so even if dead.. when someone is pulling me... I'm not suction cupped in this peanut butter mud.... hah...
oh and in addition I will be buying 2 things in march (bonus time)
http://www.hi-lift.com/hi-lift-jacks/x-treme.html
and
https://www.harborfreight.com/18000-...ake-62194.html
2017-07-18_11-34-45 by Jeffrey Riggs, on Flickr
Old July 21st, 2017, 11:13 AM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Ii happens. At least you had an equipment failure to share the blame!
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old July 21st, 2017, 11:17 AM
is that your equipment? if so that would of made life easier!!!!
I'm still trying to track down some of the people that were there.. someone has video of me getting pulled out...
Old July 21st, 2017, 11:18 AM
just fer u
Old July 21st, 2017, 01:20 PM
Pete's Avatar
Pete Pete is offline
So; do you enjoy your truck and hobby?
That is really all that matters you know.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers | Openpeak Intel Atom SoC tabletop touchscreens (15 HS tabletop tablets)
HS3 Pro & Lite
Edition Beta 3.0.0.435 | HS3 Wintel Touch | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Old July 21st, 2017, 01:27 PM
I enjoyed it for the 1st hr of stuck... 2nd hr not as much and by 5th I wanted to get home
Old July 21st, 2017, 02:47 PM
cheeryfool's Avatar
cheeryfool cheeryfool is offline
Super Seer
"Drove my Chevy to the levee but the levee wasn't dry"
cheeryfool
Old July 21st, 2017, 02:54 PM
lol
yeah u could say that.. this was a while ago but me standing on my hood giving the guy a tow strap.. yanked him out in reverse.. I hate doing that as its hard on the ring and pinion...
fullsize image - http://www.supermotors.net/getfile/5...l/dsc01130.jpg
Old July 22nd, 2017, 12:52 PM
Pete's Avatar
Is the truck all cleaned up now and ready for the next adventure?
Old July 25th, 2017, 01:28 PM
nope... well kinda...
I have my last week of Algebra in school.. 4 nights... final on Thurs...
truck is running but not cleaned inside.. hah..
so it is ready to go play if it was called upon to go and get soupy..
I also ordered up some new toys to help on getting me out next time..
another hi lift - but the extreme model this time...
also bought the hi lift offroad kit - 2 chain kits, gloves, etc...
to just start my preppin on self recovery rig.
I am on vaca from Aug4 - Aug 14, then that weekend I take the light bar out (it isn't a true rollbar)... and will be making a spare tire mount as I have a fullsize 40" ground hawg rolling around the bed... then going to figure out where to mount both hi lift jacks.
going to local steel shop (love this place) and in their military surplus room they have tons of the ammo cans in various sizes. Going to get some of them and mount them in the truck to hold everything down and are waterproof (I think that is important for me)
so more to come...
Old July 25th, 2017, 01:59 PM
logbuilder logbuilder is offline
What year is that? I have a '86 Custom Deluxe C20 that I hope to start working on soon.
Old July 26th, 2017, 02:13 PM
1978 k20 camper special (8400gvrw)
so a site I highly recommend if your going to work on something..
www.waytekwire.com
Locally wire loom is $2/ft... on there I bought a 100' box for $17.50!!! then I bought the loom T adapters, clip adapters so you can attach to fenders or stuff and also bought the break out adapters.. never used them though..
then I bought tons of other stuff from them
upper left are the waterproof GM plugs you find on cars today...
Old October 9th, 2017, 02:51 PM
drozwood90 drozwood90 is offline
Tele,
I was going to have my truck out this year (I know, I say that every year), but I really was this year. I had the $$ and everything!
Then my brother decided to get married in HI and there went all that money.
--Dan
Old October 19th, 2017, 10:30 AM
LOL
Old October 19th, 2017, 11:26 AM
thymer thymer is offline
If you get stuck again just give me a ring. Actually trying to sell it...
HS3 Prod - Win10 - DSC - HVAC-GC-TBZ48 x3 - CurrentCost - BLRadar - RFXCOM/FRXTRX433 -ADIO - HSTOUCH - BLUPS - AB8SS - SONOS - Alexa - 1 wire - BlueIris -MyQ
Old October 19th, 2017, 11:46 AM
how much? and I think VA to S.NJ is a bit far if I'm stuck.. unless your REALLY HURTING to get out!!! LOL
side note.. I'm still working on the truck after that stuck!!!!
my calipers locked (drivers side mainly) as seals were bad and truck was towed home and sat for a week. replaced both... but still a bit not right.. not sure why... wheel goes left then right but also I gotta fix the play in my steering. Watch a dukes of hazard episode and that is what its like driving this beast...
but I was working on the carb and back float was way wrong pouring fuel into the secondaries while at idle!!!! so took holley back bowl off and WOW found a HUGE vacuum leak. It was an adapter on the intake that I plugged, the rubber plug ripped off so a 1/4" hole so used the metal screw in plugs... fixed and now the truck idles right, can adjust timing easier, air fuel screws not out 2 turns but only 1/2 turn!!!!!!!!
Vacation June 21 - July 11 spud Spud Plug-Ins 0 June 20th, 2017 08:07 AM
mcsTemperature w/o licence for July Michael McSharry MCS Temperature 2 August 7th, 2005 12:15 PM
July Meeting MPodlin CHAUG - Chicago Area User's Group 1 July 5th, 2005 08:25 AM
July Meeting MPodlin CHAUG - Chicago Area User's Group 0 June 23rd, 2004 06:25 AM
