I'm trying to make use of the new '99999' capability to log how often my CT-30 thermostats lose communications via wifi to see if there is some pattern. I'm trying to determine the polling interval for my thermostats and I can't find where to access that info. If I recall, I enter that info into the plugin at the time the thermostat is discovered - but I don't want to have to rediscover the thermostats (I have five of them) because that changes the device address, and that in turn means I have to rewrite all of my scripts and events that are dependent on those device codes.
Am I missing some way to see what the polling interval is for each thermostat? Ideally, would it be possible to allow the plugin to edit those values without rediscovering the thermostat?
