*** BLLED 1.0.38 ***
    In this build I have changed the string label special tags
    The opening and closing characters have changed to [ ]
    The new format for special string tags will be:
    [devicevalue=B1|update=onchange]
    You will need to update your string values if you are using these tags.
    I changed it so it would not interfere with the special text label tags.
    Cheers,
    Bob
    Bob,
    I'm sending this message as I really would like some extra help to get BLLED functioning again for me. I'm a big fun of your plugins and have been using them for years.
    Some time ago BLLED quit working for me. I recently upgraded my theater screen and have a renewed interest in getting my theater LED sign working again but after hours and hours (literally 10 or more) I am unable to figure out what I might be doing wrong.
    A little background. I first suspected that my sign or cabling had gone bad until I found a small program called LEDSignHelloWorld, that allows you to create short messages and send to the sign. It works perfectly so I'm now ruling out computer, sign, and/or cabling. It works using both 9600,E,7,1 or 9500,N,8,1. When I try either of those settings within BLLED it does not seem to communicate with the sign at all.
    I went back to an old backup of HS4 and used BLLED (version1.066) and was able to get the sign to work sporadically. As soon as I upgrade to the latest version on the HS site (2.0.1.0) I lose all responses from the sign.
    I have attached a couple of my setup screen shots below along with a snippet form the log file.
    I suspect I am doing something stupid or missing something obvious, but I seem to be repeating the same fixes over.
    ANYTHING YOU CAN DO TO REVIEW AND HELP IS GREATLY APPRECIATED. We have a party coming over on Sunday for a party and I realty want to show this off.
    Program Settings
    String Labels
    DOTs
    Sample (non working) EVENTS
    Reset
    Garage Door Closed
    Snippet of HS log file after restarting BLLED
      In Blade’s post at the top of this thread, he shows a link to his Helpdesk. He should respond to it more quickly.
        I tried. It doesn’t look like he’s supporting the plugins anymore.
        I hated seeing that as he’s written some of the best.
