Version 3.0.1.12 was submitted to the updater this morning. I'm hopeful they get it updated by EOD.
Changes in this version:
To say this is a large update is an understatement. A lot of code went into supporting Thermostats, Units and Flags. I have tested with a couple of RC-80 Thremostats and UPB modules. You can control basic functions from the device management page, or with HS Events. In the HS Events setup, just use "Control a device..."
I had to give up (for now) on creating thermostat devices so that the default HSTouch app uses HAI thermostats. I found some posts by Kirby and others that there appears to be some secret sauce that HST uses to make Z-Wave thermostats show up in the default HSTouch app. I'm not giving up, though. I have to be able to set thermostats from my HSTouch tablets or WAF will stay at an all-time low.
I only have a single UPB device at this time. It is an appliance module, so I need you guys to test out dimming. I built support for it, but have no real way to test it. My experience with UPB so far is that it is really fast
I'll leave 3.0.1.12 in Beta status for now, but this will be moving to paid status very soon. Make sure you hold onto your license keys!
***Backup your current installation so you can revert back if needed!!
HST didnt get it loaded in the updater, so here is the EXE if you want to try it out. Shutdown the plugin, make a backup of HSPI_HAI.exe and replace it with this one.
- Added Unit support (UPB/X10).
- Added Flag support.
- Added Thermostat support.
- Fixed issue with plugin not picking up AC Fail detection (System Troubles).
- Added more device status images.
- Refactoring older code.
