Z-Seer+ Where to install?
    I have linux on a Pi-3.
    I access my instance via a win10 laptop typically
    I thought I should install a windows install and run it off my yoga win10 laptop, but it seems to have created a new blank instance of HS3 locally on the laptop. My question is, am I suppose to install this on my Pi, then restart ./go and go to the web interface and pull it up on any computer?
    It is not obvious to me.
    You dont have to do anything special on the Linux side. Z-Seer+ will just connect to HomeSeer and use the Z-Wave Plugin for the data.
    Just install Z-Seer+ on your Windows machine, point it to your HomeSeer IP and let it brew.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Here run it in an Oracle VB on the Homeseer server (running Ubuntu) and Ubuntu laptops (running VBs in W7).
        This is a little embarrassing but the PDF pointed me to the download page where there are 3 downloads Linux windows and PC Microsoft.
        That is what I downloaded it's homeseer. After reading your comments I went back and looked at that page and way down at the bottom I see Z Tool Plus
        I guess I can't read
        Your comments helped me go back and check it again so thanks
        Sent from my SM-N950U using Tapatalk
          No problem. Let us know if you have any issues.
