Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old January 25th, 2015, 03:30 PM
phuz phuz is offline
Error creating global variable and other startup error
I just realized that global variables are lost at restart, so I tried to add them in my startup.vb file, but instead I get these errors:
Jan-25 2:28:52 PM Error Compiling script Startup.vb: 'CreateVar' is not declared. It may be inaccessible due to its protection level.
Jan-25 2:28:52 PM Error Compiling script Startup.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Old January 25th, 2015, 03:37 PM
Hey look at me....
add the "hs." and everything works just fine.
D'oh!
Startup Error: Startup.vb: could not find library 'Scheduler.dll' - Solution centerisland HS3 / HS3PRO Discussion 12 January 2nd, 2017 09:57 AM
General Question on vb.NET error "Object variable or With block variable not set." heatvent Script & Plug-In Development 2 July 17th, 2008 12:10 AM
Error VR Install: Object variable or With block variable not set. gelessor HSTV 2 November 17th, 2007 11:16 PM
Getting Script error: Object variable or With block variable not set techbluecat WapSeer (3P) 3 November 3rd, 2003 10:05 AM
