I just installed the GTS plug-in, successfully into HS3. Using a mix of X10 Lamp and Appliance Modules as setup in config.
Whilst a scan with Alexa recognises all the Appliance Modules, the Lamps are not found.
I checked this, by deleting one Lamp deice in the plug-in config, then defining a new Appliance at the same address (original Lamp module still wired in at the hardware end). This worked fine.
Is this a bug or am I doing something wrong?
