Display HSTouch Version Number
    Is there any way to display the Android HSTouch version number?
    Don
    When you first start the app it displays the version and your resolution in the top left corner, its fast so you gotta watch carefully
    John
      Here I just exit and restart the client to see the client version number. I do have an exit button defined to make this a bit easier for me.
        Thanks, was hoping for a haircut function, but that will work.
        Sent from my XT1565 using Tapatalk
        Don
          Years ago when I played with HSTouch clients on Android I rooted the device, enabled SSH and VNC server. Mostly doing this for file manipulation.
          IE: you can utilize WinSCP to get to your rooted with SSH server tablet. The install apk file is just a zipped file with all of your stuff.
          Looking at my Android tablet I can go to settings / apps / application and click on application where there it mentions the version number.
          I do not have HSTouch on this tablet. Will install it and see if the version number is there.
          Installed HSTouch on Android tablet. Downloaded APK from here on the forum.
          hxxps://homeseer.com/updates3/hstouch_release_1.0.160.apk appears to be current release version.
          Checked out settings / apps and see HSTouch there, clicked on it and it shows the version number.
            Sorry meant to say hs function, but my phone had other ideas.
            Don
