Hi, all,
I am trying to get my Android tablets to dim from a Linux (HS3 ZEE S2 Edition 3.0.0.357 (Linux)) install and trying it via a script.
Using:
Sub Main(byval input as Object)
hs.PluginFunction("HSTouch Server", "", "ClientAction", {89,"HOMETROLLERZEES2:BELLA",".01",""})
End Sub
Error:
"Compiling script /usr/local/HomeSeer/scripts/DimKids.vb: Visual Basic.Net Compiler version 0.0.0.5943 Copyright (C) 2004-2010 Rolf Bjarne Kvinge. All rights reserved. /tmp/6b07faee/293ba69e.0.vb (2,16) : Warning VBNC40056: The import 'System.Core' could not be found. /tmp/6b07faee/293ba69e.0.vb (20,35) : Error VBNC99999: Internal compiler error close to this location Error : VBNC99999: Unexpected error: Object reference not set to an instance of an object at vbnc.Argument.ResolveCode (vbnc.ResolveInfo Info) [0x00000] in :0 at vbnc.BaseObjects`1[vbnc.Argument].ResolveCode (vbnc.ResolveInfo Info) [0x00000] in :0 at vbnc.ArgumentList.ResolveCode (vbnc.ResolveInfo Info) [0x00000] in :0 at vbnc.InvocationOrIndexExpression.ResolveExpressionInternal (vbnc.ResolveInfo Info) [0x00000] in :0 at vbnc.Expression.ResolveExpression (vbnc.ResolveInfo ResolveInfo) [0x00000] in :0 Compilation took 00:00:05.6631700"
Any help will be appreciated.
Using:
End Sub
Error:
