Recently I ran into a issue with getting speech to work using the Squeeze Box Plugin through LMS to Google Home. I am writing this in case anyone else runs into this issue.
1. My Windows based LMS (v7.9.0) is configured with the Chromecast bridge (v0.2.7.3). I am also using the ShareTunes plug in (v0.60.2) to play Airplay sources to Google Home.
2. I ran into issues with inconsistent speech playing on the google home from Homeseer. Sometimes manually triggering an event would play the TTS and sometimes it wouldn't. I followed several of the articles including tracking down the MP3 files in the html directory. When I went to the lms media server website I could see the mp3 file come across on the player I was sending speech to through homeseer - however it wouldn't play.
3. My HomeSeer Squeezebox Speak Proxy for the plugin is configured as Enabled Speak Proxy checked, Primary Speak Proxy checked, Speak Proxy mode Normal, TTS as MP3 checked, No lame options, 1000ms duration, 2 seconds before and 1 second after.
4. I found that the Google Home players had to be configured in LMS Settings>Player>[Audio] dropdown>Streaming Method set to "Proxied Streaming" instead of the default "Direct Streaming". Making this change fixed the issue - now every time I manually trigger an event the google home plays the speech.
5. Interestingly, if I am playing music from Apple Music on my iPhone to Google Home through LMS and I have HomeSeer speak something the music will pick up where it was after speaking - which is ideal. However, if I am playing iTunes through LMS to GoogleHome and have HomeSeer speak then the song starts over. If anyone figures out a fix for that one - please let me know.
