I have been a long time user of HS2 and have decided to upgrade to HS3PRO/ HS3. I see no problem with the port to HS3 except for converting over my Aprilaire thermostats which I have in my house.
When I was using HS2 I converted the script to support enerzone thermostats to support my Aprilaire thermostats. HS3 currently does not include Aprilaire thermostats and I need the support I had in HS2 or better...
The script I had made use of the Enerzone Thermostat Device type that HS2 had. It looks like I need to convert my HS2 script over to HS3 but I see no Enerzone Thermostat device type in HS3 that I used in HS2 to support my script.
I\'m looking for help on how to solve this problem. I\'m new to HS3 and not quite sure what I need to do to port my script. It seems like HS3 supports plugins for thermostats not scripts. I think if I had help in creating a thermostat device like we had in HS2 I could figure out the scripting. Really appreciate any help or directions on how to get support for Aprilaire thermostats in HS3/HS3PRO. Also I\'m doing this based on my 30 day trial in which I have 25 days left before I commit to buying a HS3PRO license. I really want to convert over to HS3PRO/HS3 since it has support for new devices I want to use but I cannot do it if I do not have support for Aprilaire Thermostats.
It seems like the easiest solution would be to create an Enerzone Thermostat Device type in my script but I do not know how to do this.
Any advice or ideas on how to get this support for the Aprilaire Thermostats would be greatly appreciated.
garyb
garyb
